Esp 01 is not connecting to the WiFi
Some days ago I had successfully connected my esp-01 with my wifi (on 19th of feb)
Even It was showing that
Wifi got IP
Wifi Connected
in the serial monitor
I tested on 20th and 21st of feb it was showing that it is connected to blynk nd wifi nd all.
But now I tried to do a different project with that esp that is the LED one, LED blinking project.
And In serial monitor it is showing that
Failed to connect with WiFi so i thought maybe my connection wasn’t right or esp may have got some problems. For confirming this issue I test with the simple esp-01 to arduino mega 2560 connection i.e,
Esp-01 To Arduino Mega 2560
Tx - Rx (18)
Rx - Tx (19)
CH_PD - 3.3v
Vcc - 3.3v
Gnd - Gnd
And now it is showing nothing on my serial monitor
Not even OK for AT command.
One more thing
If I connect those RX, TX to the RX, TX of 0 and 1 pin of Arduino mega then it is responding to the AT command but still not connecting to the WiFi
Plz help as I have to submit my project next week
(This is my first time on blynk community so plz understand it😉)
This is my program code
#include <ESP8266_Lib.h>
#include <Servo.h>
char auth[] = "*******************************";
char ssid[] = "**********";
char pass[] = "****************";
const int outputpin1 = 52;
const int outputpin2 = 53;
int servoPin1 = 8;
int servoPin2 = 9;
int servoPin3 = 12;
int servoPin4 = 11;
int stop1=4;
int stop2=7;
int back1=2;
int back2=5;
int pwm1=3;
int pwm2=6;
int pos=150;
int pos1=30;
int pos2=150;
int val1;
int val2;
boolean trash;
#define EspSerial Serial1
#define ESP8266_BAUD 115200
#define bintrig1 22
#define binecho1 23
#define bintrig2 24
#define binecho2 25
#define lefttrig 26
#define leftecho 27
#define righttrig 28
#define rightecho 29
#define rttrig 30
#define rtecho 31
#define rbtrig 32
#define rbecho 33
#define lttrig 34
#define ltecho 35
#define lbtrig 36
#define lbecho 37
ESP8266 wifi(&EspSerial);
Servo myservo1;
Servo myservo2;
Servo mainservo;
Servo binservo;
void myTimerEvent()
  pinMode(outputpin1, INPUT);
  pinMode(outputpin2, INPUT);
  myservo1.attach(11);
  myservo2.attach(12);
  mainservo.attach(8);
  binservo.attach(9);
  binservo.write(0);
  myservo1.write(pos1);
  myservo2.write(pos2);
  mainservo.write(pos);
  pinMode(stop1, OUTPUT);
  pinMode(stop2, OUTPUT);
  pinMode(back1, OUTPUT);
  pinMode(back2, OUTPUT);
  pinMode(pwm1, OUTPUT);
  pinMode(pwm2, OUTPUT);
  pinMode(bintrig1,OUTPUT);
  pinMode(binecho1,INPUT);
  pinMode(bintrig2,OUTPUT);
  pinMode(binecho2,INPUT);
   pinMode(lefttrig,OUTPUT);
  pinMode(leftecho,INPUT);
   pinMode(righttrig,OUTPUT);
  pinMode(rightecho,INPUT);
   pinMode(rttrig,OUTPUT);
  pinMode(rtecho,INPUT);
   pinMode(rbtrig,OUTPUT);
  pinMode(rbecho,INPUT);
   pinMode(lttrig,OUTPUT);
  pinMode(ltecho,INPUT);
   pinMode(lbtrig,OUTPUT);
  pinMode(lbecho,INPUT);
BLYNK_WRITE(1)
  if (param.asInt()==1) {
        pin1_activated();
  BLYNK_WRITE(3)
        forward();
        delay(100);
        Stop();
BLYNK_WRITE(4)
        backward();
        delay(100);
        Stop();
  BLYNK_WRITE(5)
        left();
        delay(100);
        Stop();
   BLYNK_WRITE(6)
        right();
        delay(100);
        Stop();
 BLYNK_WRITE(7)
        Stop();
  BLYNK_WRITE(12)
        forward();
  BLYNK_WRITE(13)
        backward();
BLYNK_WRITE(2)
  int x = param[0].asInt();
  int y = param[1].asInt();
  if(y>220)
  {forward();}
  else if(y<35)
  {backward();}
  else if(x>220)
  {right();}
  else if(x<35)
  {left();}
  {Stop();}
int autostate;
BLYNK_WRITE(11)
  autostate=param.asInt();
while(autostate==1){
  autonomous();}
void autonomous(){
  int ldistance,rdistance,rtdistance,rbdistance,ltdistance,lbdistance,lduration,rduration,rtduration,rbduration,ltduration,lbduration;
   digitalWrite (lefttrig, HIGH);
   delayMicroseconds (1000);
   digitalWrite (lefttrig, LOW);
   lduration = pulseIn (leftecho, HIGH);
   ldistance = (lduration/2) / 29.1;
   digitalWrite (righttrig, HIGH);
   digitalWrite (righttrig, LOW);
   rduration = pulseIn (rightecho, HIGH);
   rdistance = (rduration/2) / 29.1;
  digitalWrite (rttrig, HIGH);
   digitalWrite (rttrig, LOW);
   rtduration = pulseIn (rtecho, HIGH);
   rtdistance = (rtduration/2) / 29.1;
   digitalWrite (rbtrig, HIGH);
   digitalWrite (rbtrig, LOW);
   rbduration = pulseIn (rbecho, HIGH);
   rbdistance = (rbduration/2) / 29.1;
  digitalWrite (lttrig, HIGH);
   digitalWrite (lttrig, LOW);
   ltduration = pulseIn (ltecho, HIGH);
   ltdistance = (ltduration/2) / 29.1;
   digitalWrite (lbtrig, HIGH);
   digitalWrite (lbtrig, LOW);
   lbduration = pulseIn (lbecho, HIGH);
   lbdistance = (lbduration/2) / 29.1;
while(ldistance<0){
  ldistance=399;}
  while(rdistance<0){
  rdistance=399;}
  while(rtdistance<0){
  rtdistance=399;}
  while(ltdistance<0){
  ltdistance=399;}
  while(rbdistance<0){
  rbdistance=399;}
  while(lbdistance<0){
  lbdistance=399;}
  aforward();
if(rtdistance<28||ltdistance<28){
    Stop();
    if(rdistance>28&&ldistance>28){
        if(rdistance>=ldistance){
          aright();
          delay(4000);
          Stop();}
          else if(rdistance<ldistance){
            aleft();
            delay(4000);
            Stop();}}
     else if(rdistance<28||ldistance<28){
         if(rdistance<28&&ldistance>28){
          aleft();
          delay(4000);
          Stop();}
          else if(rdistance>28&&ldistance<28){
            aright();
            delay(4000);
            Stop();}
            else if(rdistance<28&&ldistance<28){
              aright();
              delay(8000);
              Stop();}}
 if(lbdistance<20||rbdistance<20&&rtdistance>28&&ltdistance>28){
  Stop();
  delay(100);
  if(lbdistance<20&&rbdistance<20){
    abackward();
    delay(1300);
    Stop();
    pin1_activated();
    delay(1000);}
  else if(lbdistance<20&&rbdistance>20){
    aleft();
    delay(300);
    Stop();
    abackward();
    delay(1300);
    Stop();
    pin1_activated();
    delay(1000);}
   else if(lbdistance>20&&rbdistance<20){
    aright();
    delay(300);
    Stop();
    abackward();
    delay(1300);
    Stop();
   pin1_activated();
    delay(1000);}
  else {
    aforward();}
void Stop()
  analogWrite(pwm1, 0);
  analogWrite(pwm2, 0);
void left(){
  analogWrite(pwm1, 127);
  digitalWrite(back1, LOW);
  digitalWrite(back2, LOW);
  analogWrite(pwm2, 127);
void aleft(){
  analogWrite(pwm1, 30);
  analogWrite(pwm2, 30);
void right(){
  digitalWrite(back1, HIGH);
  digitalWrite(back2, HIGH);
  void aright(){
void backward(){
void abackward(){
  void forward(){
void aforward(){
void pin1_activated(){
    for (pos = 150; pos >= 45; pos -= 1) {
    delay(7);
    for (pos1=30,pos2=150;pos1>=0,pos2<=180;pos1-=1,pos2+=1){
    delay(15);}
for (pos = 45; pos <= 105; pos += 1) {
    // in steps of 1 degree
    delay(3000);
    val1=digitalRead(outputpin1);
    val2=digitalRead(outputpin2);
    if(val1==LOW||val2==LOW){
      binservo.write(180);
      delay(2000);
      if(val1==HIGH&&val2==HIGH){
        binservo.write(0);
        delay(2000);
       delay(4000);
    for (pos = 105; pos <= 150; pos += 1) {
   for(pos1=0,pos2=180;pos1<=30,pos2>=150;pos1+=1,pos2-=1){
    delay(15);}
   void Blynk_Delay(int milli)
  int end_time = millis() + milli;
  while (millis() < end_time)
if (Blynk.connected())
yield();
  int bin1duration,bin1distance;
digitalWrite (bintrig1, HIGH);
   digitalWrite (bintrig1, LOW);
   bin1duration = pulseIn (binecho1, HIGH);
   bin1distance = (bin1duration/2) / 29.1;
   Blynk.virtualWrite(V8,bin1distance);
   if(bin1distance<20){
   Blynk.virtualWrite(V9,"METALLIC BIN FULL");
   delay(1000);}
   else if(bin1distance>20){
    Blynk.virtualWrite(V9," ");
   delay(1000);}
   int bin2duration,bin2distance;
digitalWrite (bintrig2, HIGH);
   digitalWrite (bintrig2, LOW);
   bin2duration = pulseIn (binecho2, HIGH);
   bin2distance = (bin2duration/2) / 29.1;
   Blynk.virtualWrite(V10,bin2distance);
   if(bin2distance<20){
   Blynk.virtualWrite(V9,"NON METALLIC BIN FULL");
   delay(1000);}
   else if(bin2distance>20){
   delay(1000);}
There are tons n tons of delays used throughout the sketch. Should avoid them to make your sketch compatible with Blynk.
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
@Aakash You appear to have created a second user account on the forum.
As a result, I’ve disabled your other one.
PLEASE DO NOT DO THIS AGAIN!
I’m closing this topic, as you need to continue the discussion in your original topic:
