i use this code to control my light bulbs using blynk and ESP01s
char auth[] = "AUTH key";
char ssid[] = "Name";
char pass[] = "pw";
now i want to add a 3 router details for this. for connect the strong WIFI signal or available one. in my home have 3 wifi signals
how i add all details for this code. thank you
Please edit your post and add triple backticks at the beginning and end of code, so that it displays correctly.
Do you already have code that is working without BLYNK? Or are you looking for someone to provide it?
I know that this has been discussed/asked before so maybe if you search around this forum you may find something.
Otherwise post what you have tried, and what errors are occurring, then maybe someone here could try to provide some feedback/advice.
If you are hoping someone will just write it for you and post it here, I wouldn’t hold my breath as it may be a while, and probably won’t happen.
The simple solution is to change your WiFi setup so that all the SSIDs and passwords are the same.
//============================ Connect_1
if (Blynk.connect() == false) {
WiFi.begin (ssid, pass);
Blynk.config (auth);
Blynk.connect(15000);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
break;
//=============================== Connect_2
WiFi.begin (ssid_1, pass_1);
break;
//=============================== Connect_3
WiFi.begin (ssid_2, pass_2);
ESP.restart();
Please edit your post and add triple backticks at the beginning and end of your code so that it displays correctly.
