Errors in blynk.log
Hey all, I’m getting some errors in my Blynk.log file.
I think it has to with a hardware failure of the network card, but I’d like to confirm that before I rip everything apart and put in a new ethernet adapter :slight_smile: It’s also on irregular times, sometimes it doesn’t show up at all, so that’s why I think it’s some wonky hardware.
Output coming ( a lot … ):
OpenELEC:/var/media/Data2/blynk-files/logs # cat blynk.log 00:52:42.506 WARN - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception. java.io.IOException: Connection timed out at sun.nio.ch.FileDispatcherImpl.read0(Native Method) at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:223) at sun.nio.ch.IOUtil.read(IOUtil.java:192) at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:380) at io.netty.buffer.UnpooledUnsafeDirectByteBuf.setBytes(UnpooledUnsafeDirectByteBuf.java:358) at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:897) at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:242) at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:119) at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:564) at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:505) at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:419) at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:391) at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:145) at java.lang.Thread.run(Thread.java:745) 00:52:47.298 WARN - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception. io.netty.handler.codec.DecoderException: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 64 not supported message. at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:442) at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:248) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:86) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1280) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:890) at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131) at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:564) at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:505) at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:419) at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:391) at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:145) at java.lang.Thread.run(Thread.java:745) Caused by: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 64 not supported message. at cc.blynk.server.core.protocol.model.messages.MessageFactory.produce(MessageFactory.java:104) at cc.blynk.server.core.protocol.handlers.decoders.MessageDecoder.decode(MessageDecoder.java:57) at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:411) ... 20 more 01:54:45.238 INFO - iphone@lichtsignaal.nl hardware joined. 03:15:47.027 WARN - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception. io.netty.handler.codec.DecoderException: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 64 not supported message. at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:442) at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:248) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:86) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1280) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:890) at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131) at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:564) at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:505) at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:419) at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:391) at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:145) at java.lang.Thread.run(Thread.java:745) Caused by: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 64 not supported message. at cc.blynk.server.core.protocol.model.messages.MessageFactory.produce(MessageFactory.java:104) at cc.blynk.server.core.protocol.handlers.decoders.MessageDecoder.decode(MessageDecoder.java:57) at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:411) ... 20 more 04:21:46.865 WARN - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception. io.netty.handler.codec.DecoderException: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 64 not supported message. at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:442) at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:248) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:86) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1280) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:890) at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131) at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:564) at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:505) at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:419) at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:391) at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:145) at java.lang.Thread.run(Thread.java:745) Caused by: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 64 not supported message. at cc.blynk.server.core.protocol.model.messages.MessageFactory.produce(MessageFactory.java:104) at cc.blynk.server.core.protocol.handlers.decoders.MessageDecoder.decode(MessageDecoder.java:57) at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:411) ... 20 more 05:36:26.603 WARN - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception. io.netty.handler.codec.DecoderException: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 64 not supported message. at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:442) at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:248) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:86) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1280) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:890) at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131) at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:564) at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:505) at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:419) at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:391) at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:145) at java.lang.Thread.run(Thread.java:745) Caused by: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 64 not supported message. at cc.blynk.server.core.protocol.model.messages.MessageFactory.produce(MessageFactory.java:104) at cc.blynk.server.core.protocol.handlers.decoders.MessageDecoder.decode(MessageDecoder.java:57) at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:411) ... 20 more 08:23:51.090 WARN - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception. java.io.IOException: Connection timed out at sun.nio.ch.FileDispatcherImpl.read0(Native Method) at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:223) at sun.nio.ch.IOUtil.read(IOUtil.java:192) at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:380) at io.netty.buffer.UnpooledUnsafeDirectByteBuf.setBytes(UnpooledUnsafeDirectByteBuf.java:358) at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:897) at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:242) at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:119) at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:564) at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:505) at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:419) at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:391) at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:145) at java.lang.Thread.run(Thread.java:745) 08:30:04.427 INFO - Using data dir '/media/Data2/blynk-files' 08:30:17.848 INFO - Region : local 08:30:21.070 INFO - Initializing mail transport. Username : whizzcat@gmail.com. SMTP host : smtp.gmail.com:587 08:30:33.800 INFO - Plain tcp/ip hardware server port 8442. 08:30:54.944 INFO - SSL hardware port 8441. 08:30:55.203 WARN - Found server certificates but no client certificate for '/storage/blynk' path. Using one way ssl. 08:30:55.583 INFO - Application server port 8443. 08:30:56.785 INFO - HTTP API port 8080. 08:30:57.577 INFO - HTTPS API port 9443. 08:30:58.325 INFO - HTTPS admin UI port 7443. 08:30:58.349 INFO - Web Sockets port 8082. 08:30:58.570 INFO - Web SSL Sockets port 8081. 08:31:04.674 INFO - iphone@lichtsignaal.nl hardware joined. 08:31:06.117 WARN - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception. io.netty.handler.codec.DecoderException: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 192 not supported message. at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:442) at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:248) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:86) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1280) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:890) at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131) at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:564) at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:505) at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:419) at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:391) at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:145) at java.lang.Thread.run(Thread.java:745) Caused by: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 192 not supported message. at cc.blynk.server.core.protocol.model.messages.MessageFactory.produce(MessageFactory.java:106) at cc.blynk.server.core.protocol.handlers.decoders.MessageDecoder.decode(MessageDecoder.java:57) at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:411) ... 20 more 08:31:25.644 INFO - iphone@lichtsignaal.nl hardware joined. 08:31:30.685 WARN - User not logged. /192.168.0.47:1047. Closing. 08:31:30.700 WARN - User not logged. /192.168.0.47:1047. Closing. 08:31:36.598 INFO - iphone@lichtsignaal.nl hardware joined. 08:34:50.665 WARN - User not logged. /192.168.0.47:1049. Closing. 08:34:50.672 WARN - User not logged. /192.168.0.47:1049. Closing. 08:34:56.581 INFO - iphone@lichtsignaal.nl hardware joined. 08:51:25.953 WARN - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception. io.netty.handler.codec.DecoderException: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 192 not supported message. at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:442) at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:248) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:86) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:321) at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1280) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:342) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:328) at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:890) at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131) at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:564) at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:505) at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:419) at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:391) at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:145) at java.lang.Thread.run(Thread.java:745) Caused by: cc.blynk.server.core.protocol.exceptions.UnsupportedCommandException: Command with code 192 not supported message. at cc.blynk.server.core.protocol.model.messages.MessageFactory.produce(MessageFactory.java:106) at cc.blynk.server.core.protocol.handlers.decoders.MessageDecoder.decode(MessageDecoder.java:57) at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:411) ... 20 more 08:51:45.476 INFO - iphone@lichtsignaal.nl hardware joined.
Hello. This error means that Blynk command that hardware sends to server is not well-formed. It could be ehternet adapter, it could be network issue it could be hardware specific problem.
Is there anyway I can determine which device is causing this? I use a couple ESP’s and one Arduino, but I’m not sure which one causes this. It could be malfunctioning wifi adapters too. How do I set the log level so I can see this? Or even an authtoken would be nice so I can rule out either the Wifi network or the wired lan :slight_smile:
It requires additional logging in code. I’ll add more logging however you’ll need new version of server to see this.
Sure thing, that’s no problem with my awesome version management (e.g. a symlink to the jar-file, lol).
I’ve did a bit the hardcore way, I turned off all my ESP’s and other blynk devices so the only thing left was the Mega with the Ethernet port and guess? Same stuff :frowning:
I’m trying with another Mega, but so far no luck, It still doesn’t work…
So you getting those errors only when MEGA is online? Could you please post code?
It’s my very long Home Domotic code, so I was thinking of using the Basic Ethernet example with the ENC28J60 first with that auth token and see what happens
I think I figured it out, finally.
What I did was reduce the code back to the example for the Mega and try ESP as a shield, made new wiring for the ENC (twice), tried two Mega’s, two ENC’s, made wiring again and I couldn’t reproduce it, so I decided to start from scratch with coding.
Based on one simple thing a Buffer overflow started happening when I connected with my ESP and I think it’s responsible for the ENC not functioning good either. I had:
BLYNK_CONNECTED
  lights.setAuthtoken(blablabla);
 Blynk.syncAll();
I think the Auth token setting was responsible for the overflow and the network disconnecting cause it kept repeating it, the syncAll feature doesn’t seem to be affecting this though. This was a historical thing from a couple versions back which I added on request of one of you guys :slight_smile:
-edit-
Figures, that’s not it … still getting Buffer overflow :frowning:
