Hello, I try to use the virtualWrite command in a script and the command work one time in two. The objective is to set at 0 two virtual pins, V6 and V7, when I click on the virtual pin V8 (on a vertical step).
The two virtual pins set 9 score variables in terms of the last virtual pin (innings).
I use an Arduino Mega with a HC-05 bluetooth module. And I have a local server 0.41.14 on java8 on a Raspberry Pi 2 B but I try on the Blynk’s servers and it’s the same thing.
(sorry for the mistakes i’m a french student)
//-------------Blynk-------------//
char auth[] = "X7XRIjkJ0RncKxrH_J-Zw4o7qZW4JU4L";
//-----------Variables-----------//
int mancheNumber = 1;
int SM1H = 0;
int SM2H = 0;
int SM3H = 0;
int SM4H = 0;
int SM5H = 0;
int SM6H = 0;
int SM7H = 0;
int SM8H = 0;
int SM9H = 0;
int SM1V = 0;
int SM2V = 0;
int SM3V = 0;
int SM4V = 0;
int SM5V = 0;
int SM6V = 0;
int SM7V = 0;
int SM8V = 0;
int SM9V = 0;
//-----------Fonctions-----------//
void refrechMancheNum(int x)
mancheNumber = x;
void refrechScoreH(int x)
if (mancheNumber == 1)
SM1H = x;
if (mancheNumber == 2)
SM2H = x;
if (mancheNumber == 3)
SM3H = x;
if (mancheNumber == 4)
SM4H = x;
if (mancheNumber == 5)
SM5H = x;
if (mancheNumber == 6)
SM6H = x;
if (mancheNumber == 7)
SM7H = x;
if (mancheNumber == 8)
SM8H = x;
if (mancheNumber == 9)
SM9H = x;
void refrechScoreV(int x)
SM1V = x;
SM2V = x;
SM3V = x;
SM4V = x;
SM5V = x;
SM6V = x;
SM7V = x;
SM8V = x;
SM9V = x;
void printa () //print function to check if the script work
Serial.print(SM1H);
Serial.print(" ");
Serial.print(SM2H);
Serial.print(" ");
Serial.print(SM3H);
Serial.print(" ");
Serial.print(SM4H);
Serial.print(" ");
Serial.print(SM5H);
Serial.print(" ");
Serial.print(SM6H);
Serial.print(" ");
Serial.print(SM7H);
Serial.print(" ");
Serial.print(SM8H);
Serial.print(" ");
Serial.print(SM9H);
Serial.print(" - ");
Serial.print(SM1V);
Serial.print(" ");
Serial.print(SM2V);
Serial.print(" ");
Serial.print(SM3V);
Serial.print(" ");
Serial.print(SM4V);
Serial.print(" ");
Serial.print(SM5V);
Serial.print(" ");
Serial.print(SM6V);
Serial.print(" ");
Serial.print(SM7V);
Serial.print(" ");
Serial.print(SM8V);
Serial.print(" ");
Serial.println(SM9V);
//--------Fonctions Blynk--------//
BLYNK_WRITE(V6) //Score H
int sh = param.asInt();
refrechScoreH(sh);
printa();
BLYNK_WRITE(V7) //Score V
int sv = param.asInt();
refrechScoreV(sv);
printa();
BLYNK_WRITE(V8) //Numéro de la manche
Blynk.virtualWrite(V6, 0);
Blynk.virtualWrite(V7, 0);
int m = param.asInt();
refrechMancheNum(m);
DebugSerial.begin(9600);
DebugSerial.println("Waiting for connections...");
Blynk.begin(Serial, auth);
