Error with my blynk IOT code pls anyone help me
This is the code
After compling this i get an error called : Compilation error: ‘class BlynkWifi’ has no member named ‘virtualRead’
please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly. Triple backticks look like this: ```
@Shksk you appear to have edited your post, but instead of copying and pasting the triple backtick example that @Madhukesh provided, you’ve used different characters - which don’t work.
Please fix your code formatting correctly, otherwise your unformatted code will be deleted.
Blynk.virtualRead(vPin) isn’t supported in Blynk IoT
