I get an error as such while using automatic certificate generation
I port forwarded the required ports
I made necessary changes to the server.properties file
server.host=smomehomeautomation.com product.name=Smome #email used for certificate registration, could be omitted in case you already specified it in mail.properties contact.email=264sanjay@gmail.com
below this line is my server logs
15:55:46.271 INFO - Using data dir ‘server_data’
15:55:47.058 INFO - Region : local. Host : smomehomeautomation.com.
15:55:47.907 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
15:55:47.991 INFO - Didn’t find custom user certificates.
15:55:47.991 INFO - Didn’t find Let’s Encrypt certificates.
15:55:47.991 INFO - Automatic certificate generation is turned ON.
15:55:47.991 WARN - ATTENTION. Server certificate paths (cert : ‘C:\Users\Sanjay\Smome\Smome Server’, key : ‘C:\Users\Sanjay\Smome\Smome Server’) not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
15:55:49.336 INFO - Hardware plain tcp/ip server listening at 8442 port.
15:55:49.336 INFO - Hardware SSL server listening at 8441 port.
15:55:49.354 INFO - Application server listening at 8443 port.
15:55:49.357 INFO - HTTP API and WebSockets server listening at 8080 port.
15:55:49.358 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
15:55:49.358 INFO - Mqtt hardware server listening at 8440 port.
15:55:49.374 INFO - Starting up certificate retrieval process for host smomehomeautomation.com and email 264sanjay@gmail.com.
15:55:54.251 INFO - Registered a new user, URI: https://acme-v01.api.letsencrypt.org/acme/reg/29267749
15:55:55.297 INFO - Authorization for domain smomehomeautomation.com -
this is where the log ends
How do I fix this
