Error - Reconnect every time
Hi , i have problem with my project…
Check ->
Arduino Mega 2560 With Ethernet Shield W5100…
Monitor Show this.
 [0] Getting IP...
 [6689] IP:192.168.1.19
 [6690]
 ___  __          __
/ _ )/ /_ _____  / /__
   / _  / / // / _ \/  '_/
  /____/_/\_, /_//_/_/\_\
 /___/ v0.6.1 on Arduino Mega
 [6808] Connecting to 192.168.1.14
 [6900] Ready (ping: 8ms).
 [12192] Connecting to 192.168.1.14
 [17193] Connecting to 192.168.1.14
Code:
 #include <Ethernet.h>
 #include <DHT.h>
 #include <Wire.h>
 #include <TimeLib.h>
 #include <WidgetRTC.h>
 #define DHTPIN 23
 #define DHTTYPE DHT11     // DHT 11
 char auth[] = "";
 #define W5100_CS  10
 #define SDCARD_CS 4
 WidgetTerminal terminal(V73);
 WidgetLED ledbomba(V72);
 DHT dht(DHTPIN, DHTTYPE);
 WidgetRTC rtc;
 const int BombaAgua = 22;
 const int ReflectorPatio = 24;
 const int Presurizadora = 26;
 const int NivelTanke = 28;
 const int SensorPorton = 52;
 const int BotonCuarto = 50;
 const int ReflectorPorton = 53;
 const int ReflectorTerreno = 51;
 const int AperturaPorton = 49;
 const int LuzCuarto = 47;
 int EstadoBombaAgua = LOW;
 int EstadoReflectorPatio = LOW;
 int EstadoPresurizadora = LOW;
 int EstadoNivelTanke = LOW;
 bool isFirstConnect = false;
 int EstadoLuzCuarto, EstadoBotonCuarto, EstadoReflectorPorton, EstadoReflectorTerreno, stadoAperturaPorton, EstadoSensorPorton;
 int HoraDia = 5;
 int HoraNoche = 20;
   pinMode(SDCARD_CS, OUTPUT);
   digitalWrite(SDCARD_CS, HIGH);
   Blynk.begin(auth, IPAddress(192, 168, 1, 14), 8080);
   pinMode(BombaAgua, OUTPUT);
   pinMode(ReflectorPatio, OUTPUT);
   pinMode(Presurizadora, OUTPUT);
   pinMode(LuzCuarto, OUTPUT);
   pinMode(ReflectorPorton, OUTPUT);
   pinMode(ReflectorTerreno, OUTPUT);
   pinMode(AperturaPorton, OUTPUT);
   pinMode(BotonCuarto, INPUT_PULLUP);
   pinMode(SensorPorton, INPUT_PULLUP);
   pinMode(NivelTanke, INPUT_PULLUP);
   dht.begin();
   rtc.begin();
   setSyncInterval(10 * 60);
   terminal.clear();
   terminal.println(F("Jarvis Home Iniciado V2"));
   terminal.println(F("-------------"));
   terminal.println(F("Version: " BLYNK_VERSION));
   terminal.flush();
   timer.setInterval(1000L, botonluzcuarto);
   timer.setInterval(1000L, temperaturayhumedad);
 timer.setInterval(1000L, checkconnect);
   timer.setInterval(1000L, sensorporton);
   timer.setInterval(1000L, encendidoautomatico);
 BLYNK_CONNECTED() {
   if (isFirstConnect) {
 Blynk.syncAll();
   Blynk.syncVirtual(V1);
   Blynk.syncVirtual(V2);
   Blynk.syncVirtual(V3);
 BLYNK_WRITE(V1) {
   EstadoBombaAgua = param.asInt();
   digitalWrite(BombaAgua, EstadoBombaAgua);
   if (EstadoBombaAgua == 0) {
 ledbomba.on();
 terminal.println(F("Bomba Encendida"));
 terminal.flush();
   else {
 ledbomba.off();
 terminal.println(F("Bomba Apagada"));
 terminal.flush();
 BLYNK_WRITE(V2) {
   EstadoReflectorPatio = param.asInt();
   digitalWrite(ReflectorPatio, EstadoReflectorPatio);
   terminal.println(F("Reflector Patio: "));
   terminal.println(EstadoReflectorPatio);
   terminal.flush();
 BLYNK_WRITE(V3) {
   EstadoPresurizadora = param.asInt();
   digitalWrite(Presurizadora, EstadoPresurizadora);
   if (EstadoPresurizadora == 0) {
 Blynk.virtualWrite(V103, "Presurizada");
   else {
 Blynk.virtualWrite(V103, "Normal");
 BLYNK_WRITE(V4) {
   EstadoLuzCuarto = param.asInt();
   digitalWrite(LuzCuarto, EstadoLuzCuarto);
 BLYNK_WRITE(V5) {
   EstadoReflectorPorton = param.asInt();
   digitalWrite(ReflectorPorton, EstadoReflectorPorton);
 BLYNK_WRITE(V6) {
   EstadoReflectorTerreno = param.asInt();
   digitalWrite(ReflectorTerreno, EstadoReflectorTerreno);
 BLYNK_WRITE(V7) {
   EstadoAperturaPorton = param.asInt();
   digitalWrite(AperturaPorton, EstadoAperturaPorton);
 BLYNK_WRITE(V8)
   HoraNoche = param.asInt();
   terminal.println("Hora Noche Modificada: ");
   terminal.println(HoraNoche);
   terminal.flush();
 BLYNK_WRITE(V9)
   HoraDia = param.asInt();
   terminal.println("Hora Dia Modificada: ");
   terminal.println(HoraDia);
   terminal.flush();
 void sensorporton()
   EstadoSensorPorton = digitalRead(SensorPorton);
   int hora = hour();
   if (hora >= HoraDia && hora <= HoraNoche) {
 terminal.println("Sensonr Porton Activo");
 terminal.flush();
 if (EstadoSensorPorton != 0) {
   Blynk.virtualWrite(V5, "1");
   Blynk.virtualWrite(V5, "0");
 void botonluzcuarto()
   if (digitalRead(BotonCuarto) == LOW) {
 if (EstadoBotonCuarto != LOW) {
   EstadoLuzCuarto = !EstadoLuzCuarto;
   Blynk.virtualWrite(V4, EstadoLuzCuarto);
 EstadoBotonCuarto = LOW;
 EstadoBotonCuarto = HIGH;
 void temperaturayhumedad()
   float h = dht.readHumidity();
   if (isnan(h) || isnan(t)) {
 String currentDate = String(day()) + "/" + month() + "/" + year();
 terminal.println("Error Temperatura Cuarto Kevin: ");
 terminal.print(currentTime);
 terminal.print(" ");
 terminal.print(currentDate);
 terminal.println();
 terminal.flush();
 return;
   Blynk.virtualWrite(V10, h);
   Blynk.virtualWrite(V11, t);
 void checkconnect()
   bool result = Blynk.connected();
   if (result == false) {
 Blynk.connect();
 void sensortanque()
   EstadoNivelTanke = digitalRead(NivelTanke);
   if (EstadoBombaAgua != 0) {
 Blynk.virtualWrite(V1, 1);
   } else
 Blynk.virtualWrite(V1, 0);
 void encendidoautomatico()
   int hora = hour();
 if (EstadoReflectorPatio != 0) {
   Blynk.virtualWrite(V2, "1");
   Blynk.virtualWrite(V2, "0");
 if (EstadoReflectorPorton != 0) {
 if (EstadoReflectorTerreno != 0) {
   Blynk.virtualWrite(V6, "1");
   Blynk.virtualWrite(V6, "0");
 if (EstadoPresurizadora != 0) {
   Blynk.virtualWrite(V3, "1");
   Blynk.virtualWrite(V3, "0");
Im using LOCAL Server with Raspberry pi 3.
Can you please put triple back-ticks around your code (```), instead of using the block quote?
yes , Sorry.
I fixed the error , i change PINS
i think 1 conflit with Ethernet Shield.
I have another question that I would like to resolve if I am wrong …
The idea is to change the status of pins within 1 hour.
That is to say.
If i set
Time Day = 5
HourNight = 20
I need to make between 5 and 20 some pins are set to 1.-
And the rest of the hours are in state 0.
But I only need it to run 1 time since if I do it in a loop I can’t turn anything on manually because the 2nd part of the IFF turns them off.
