Error installing local file server on Raspberry Pi2
When I enter the command:
wget “https://github.com/blynkkk/blynk-server/releases/download/v0.28.3/server-0.28.3-java8.jar
I get the error:
HTTP request sent, awaiting response… 200 OK
Length: 17662042 (17M) [application/octet-stream]
server-0.28.3-java8.jar: Permission denied
Cannot write to ‘server-0.28.3-java8.jar’ (Permission denied).
@David_C_Busby try to prefix the command with sudo to see if that helps.
Thanks! It worked.
In the Linux world, sudo is king :wink:
The source of these excellent comics… https://xkcd.com/149/
