BLYNK
Error - esp is not responding
I am using Arduino Uno and Esp8266 wifi module
Here is my code =
 #include <ESP8266_Lib.h>
 char auth[] = "f5836b45973e43a1b4c8d6ed42aa5417";
 char ssid[] = "Juan Felix";
 char pass[] = "1234567890";
 //#define EspSerial Serial1
 SoftwareSerial EspSerial(0, 1); // RX, TX
 // Your ESP8266 baud rate:
 #define ESP8266_BAUD 115200
 ESP8266 wifi(&EspSerial);`
 // Attach virtual serial terminal to Virtual Pin V1
 WidgetTerminal terminal(V1);
 // You can send commands from Terminal to your hardware. Just use
 // the same Virtual Pin as your Terminal Widget
 BLYNK_WRITE(V1)
   // if you type "Marco" into Terminal Widget - it will respond: "Polo:"
   if (String("Marco") == param.asStr()) {
     terminal.println("You said: 'Marco'") ;
     terminal.println("I said: 'Polo'") ;
     // Send it back
     terminal.print("You said:");
     terminal.write(param.getBuffer(), param.getLength());
     terminal.println();
   // Ensure everything is sent
   terminal.flush();
   // Set ESP8266 baud rate
   //Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
  // Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
   // This will print Blynk Software version to the Terminal Widget when
   // your hardware gets connected to Blynk Server
   terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
   terminal.println(F("-------------"));
   terminal.println(F("Type 'Marco' and get a reply, or type"));
   terminal.println(F("anything else and get it printed back."));
   terminal.flush();
It can use for upload data to arduino uno. When i want to connect it i got this error
error
I fixed your post as per the directions…
As for your issue, please search this forum for keywords like Arduino, UNO, ESP-01, Shield, and so on… every conceivable issue has been discussed and resolved multiple times.
In your case, you are using the wrong pins for SoftwareSerial… pins 0 & 1 are needed for USB programing and the IDE Serial Monitor.
You are also using the wrong BAUD rate… stick with 9600 for best reliability with SoftwareSerial… and that is probaly what your ESP is preset for anyhow.
Blynk - RE-SEAR-CH
Then i should change it back to 2 and 3 ?
Whatever compatible pins you want.
https://www.arduino.cc/en/Reference/SoftwareSerial
after i change it i get this error
error
Now it is 1605 error
Sorry, I don’t wish to repeat all my past suggestions about using ESP as shield more than a couple of dozen times over the year… so please search this forum as suggested, and try all the options until you don’t get that error anymore :wink:
PS, the number between the brackets is the milliseconds since power up, it is not an error number.
