Error compiling for the Arduino Uno board
/* Fill-in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID           "TMPxxxxxx"
#define BLYNK_TEMPLATE_NAME         "Device"
#define BLYNK_AUTH_TOKEN            "YourAuthToken"
#include <ESP8266_Lib.h>
char pass[] = "YourPassword";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 38400
ESP8266 wifi(&EspSerial);
  // Set ESP8266 baud rate
  Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass);
  //Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass, "blynk.cloud", 80);
  //Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
  // to avoid delay() function!
Hello I need help I try to load this project on my arduino uno with ESP8266 wifi module.
error:
```Not used: C:\Users\User\Documents\Arduino\libraries\Blynk
Using BlynkESP8266_Lib library in folder: C:\Users\Usuario\Documents\Arduino\libraries\BlynkESP8266_Lib (legacy)
Using Blynk_Esp8266AT_WM library with version 1.3.1 in the folder: C:\Users\Usuario\Documents\Arduino\libraries\Blynk_Esp8266AT_WM
Using Blynk library with version 1.2.0 in the folder: C:\Users\Usuario\Documents\Arduino\libraries\Blynk
exit status 1
Error compiling for the Arduino Uno board.```
@neurona Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
sorry Pete
You need to un-install this library.
Thanks Pete all good
