Error compiling for nodeMCU
Hello
//#define BLYNK_DEBUG           // Comment this out to disable debug and save space
#include <ESP8266WebServer.h>
//#include <SimpleTimer.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <Ticker.h>              //for LED status
Ticker ticker;
char auth[] = "AuaqUFd4QhKOCDMn-KT3wredQo-p1hrm";
char ssid[] ="lavnaya";
char pass[] ="lavnaya.kiruba";
WidgetRTC rtc;
BLYNK_ATTACH_WIDGET(rtc, V6)
WidgetTerminal terminal(V2);
WidgetLCD lcd(V7);
bool simulation = false;
byte sensorInterrupt = 4;   // WeMos & NodeMCU D2
byte sensorPin       = 4;   // WeMos & NodeMCU D2
byte pumpInterrupt   = 5; //2;  //5;   // WeMos D1 ModeMCU D3
byte pumpPin         = 5; //2;  //5;   // WeMos D1 ModeMCU D3
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per litre/minute of flow.
float calibrationFactor = 4.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
#define averageperiod 5         // currently set to average the flow every 5 seconds
int countseconds = 0;           // count up to averageperiod
int averageflow = 0;            // used for averaging flow over averageperiod
bool notificationsent = false;  // to ensure just one message for each flow start
bool pumpState = false;         // pump is OFF on start up
bool masterState = false;       //
bool flowoffprintonce = false;  // to ensure just one serial and terminal print for each flow stop
int rowIndex = 0;                //Saurabh
String currentDate  ;
String daybefore;
int rtctimer = 1; //check if RTC is OK and then disable / delete this #1 timer
int currentDatesi = 0;         //Saurabh simulation
int daybeforesi=currentDatesi;
int menu=0;
int s;
  Serial.println();
 pinMode(sensorPin, INPUT);
 digitalWrite(sensorPin, HIGH);
  pinMode(pumpPin, OUTPUT);
  digitalWrite(pumpPin, LOW);  // ACTIVE HIGH, pump relay set to OFF on restart
  flowMilliLitres   = 0;
  totalMilliLitres  = 0;
  oldTime           = 0;
  flowRate          = 0.0;
  if(simulation == true){
    pulseCount        = 47;
  else{
    pulseCount        = 0;
  // Configured to trigger on a FALLING state change (transition from HIGH state to LOW state)
  attachInterrupt(sensorInterrupt, pulseCounter, FALLING);//FALLING
  // Configured to trigger on a CHANGE state change LOW to HIGH or HIGH to LOW
  attachInterrupt(pumpInterrupt, pumpToggle, CHANGE);
  rtc.begin();
  terminal.println("Connected to Blynk");
  terminal.println(WiFi.localIP());
  terminal.flush();
  timer.setInterval(1000L, showFlow);
  timer.setInterval(100L, pumpControl);  // check if pump needs to be switched ON or OFF every 0.1s
  rtctimer = timer.setInterval(2000L, checkRTC);   // check every 2s if RTC is correct
BLYNK_CONNECTED() {
Blynk.syncVirtual(V5);
Blynk.syncVirtual(V4);
void showFlow()  // average the flow over averageperiod
    detachInterrupt(sensorInterrupt);  // Disable the interrupt while calculating flow rate and sending the value to the host
    // Because this loop may not complete in exactly 1 second intervals we calculate
    // the number of milliseconds that have passed since the last execution and use
    // that to scale the output. We also apply the calibrationFactor to scale the output
    // based on the number of pulses per second per units of measure (litres/minute in
    // this case) coming from the sensor.
    flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
    // Note the time this processing pass was executed. Note that because we've
    // disabled interrupts the millis() function won't actually be incrementing right
    // at this point, but it will still return the value it was set to just before
    // interrupts went away.
    oldTime = millis();
    // Divide the flow rate in litres/minute by 60 to determine how many litres have
    // passed through the sensor in this 1 second interval, then multiply by 1000 to
    // convert to millilitres.
    flowMilliLitres = (flowRate / 60) * 1000;
    // Add the ml passed in this second to the cumulative total
    totalMilliLitres += flowMilliLitres;
    // Print the flow rate for this second in litres / minute
    Serial.print("Flow rate: ");
    Serial.print(int(flowRate));  // Print the integer part of the variable
    Serial.print("L/min");
    Serial.print("\t");          // Print tab space
    // Print the cumulative total of litres flowed since starting
    Serial.print("Output Liquid Quantity: ");
    Serial.print(totalMilliLitres);
    Serial.print("mL");
    Serial.print(totalMilliLitres/1000);
    Serial.println("L");
    if(simulation != true){
      pulseCount = 0; // Reset the pulse counter so we can start incrementing again
    countseconds++;
    if(countseconds > 0){    // used to skip the first rogue data flow reading
      averageflow = averageflow + flowRate;   // used to calculate the average flow over averageperiod cycles
    if(countseconds == averageperiod){
      Serial.print("Average water flow in litres / M is ");
      Serial.println(averageflow / averageperiod);
      Blynk.virtualWrite(V0, int(averageflow) / averageperiod);
      Blynk.virtualWrite(V1, totalMilliLitres/1000);
      countseconds = 0;  // reset the counter
      chkFlow();
      averageflow = 0;     // reset the average but only after chkFlow() function
    attachInterrupt(sensorInterrupt, pulseCounter, FALLING);  // Enable the interrupt again now that we've finished sending output
void chkFlow(){
  if((averageflow > 3) && (notificationsent == false)){  // guess of a decent water pressure
    Serial.println("Water IS flowing.");
    lcd.clear();
    lcd.print(0,0,"Water is flowing");
    Blynk.email("Water Flow Sensor", "Water IS flowing.");
    Blynk.notify("Sensor: Water IS flowing.");
    notificationsent = true;         // stop getting messages until water stops flowing and starts again
    flowoffprintonce = false;        // when water stops flowing again we can restart serial and terminal print (once)
  if((averageflow <= 3)&& (flowoffprintonce == false)){
    Serial.println("Water is NOT flowing.");
    lcd.clear();
    lcd.print(1,0,"Water is NOT");
    lcd.print(4,1,"flowing");
    notificationsent = false;  // when water starts flowing again we can send another notification
    flowoffprintonce = true;      // stop serial and terminal prints after first pass of water stopping
    s=0;
 if(averageflow <= 3){
     digitalWrite(pumpPin, LOW);   // turn off pump //s*
if(averageflow>3 && menu == 1){
    digitalWrite(pumpPin, HIGH);   // turn on pump //s*
    Blynk.virtualWrite(V8, "ON");
    Blynk.virtualWrite(V4, 1);     // update app button on V4  COSTAS//s*
void pulseCounter()
  pulseCount++;  // Increment the pulse counter
void pumpToggle(){                // toggle just pumpState OFF and ON from pin interrupt
  pumpState = !pumpState;         // don't do anything else in this function or the system will crash
  //Serial.println(pumpState);      // for debugging only  TODO comment this out later
void pumpControl()                // toggle pump OFF and ON
  detachInterrupt(pumpInterrupt);  // disable interrupt
  if(pumpState == masterState){
    // do nothing
  else{
    masterState = pumpState;
    if(pumpState == true){
    // Blynk.setProperty(V8, "color","#48E06B");
    Serial.println("Pump turned ON");
    else{
      Blynk.virtualWrite(V4, 0);
      Blynk.virtualWrite(V8, "OFF");
   //   Blynk.setProperty(V8, "color","#04C0F8");
      Serial.println("Pump turned OFF");
  terminal.flush();
  attachInterrupt(pumpInterrupt, pumpToggle, CHANGE);   // enable pump pin interrupt
void checkRTC(){
  if(year() != 1970){
    timer.disable(rtctimer);  // disable rtctimer now RTC is ok
    //rtcupdated = true; // can be commented out as checkRTC will stop when RTC is ok
    currentDate = String(day()) + "/" + month() + "/" + year();   // etc
    terminal.println("RTC started");
    daybefore=currentDate;
    timer.setInterval(60000L, table);   //start table() now RTC is OK
void table()                               //Saurabh
   if(currentDate != daybefore)
    //currentDate = String(day()) + "/" + month() + "/" + year();
    Blynk.virtualWrite(V10, "add", rowIndex,daybefore,totalMilliLitres/1000+String(" litre")); //Saurabh
    Blynk.virtualWrite(V1, 0);
    Serial.println("working");
BLYNK_WRITE(V3){   // reset with button in PUSH mode on virtual pin 3
  int resetdata = param.asInt();
  if(resetdata == 1){
    Serial.println("Clearing data");
    Blynk.virtualWrite(V0, 0);
    averageflow = 0;
    countseconds = 0;
BLYNK_WRITE(V20){   // reset with button in PUSH mode on virtual pin 20
  if(resetdata == 1){
    Serial.println("Clearing table data");
    Blynk.virtualWrite(V10, "clr");
BLYNK_WRITE(V4){   // Button in SWITCH mode on virtual pin 4 to control relay
  int controlRelay = param.asInt();
  if(controlRelay == 1){
    digitalWrite(pumpPin, HIGH);  // turn relay ON
   // Blynk.virtualWrite(V8, "ON");
  else{
    digitalWrite(pumpPin, LOW);  // turn relay OFF
     //Blynk.virtualWrite(V8, "OFF");
  pumpControl();
BLYNK_WRITE(V5)
 switch(param.asInt()){
  case 1:{
     lcd.clear();
    lcd.print(1,0,"Automatic Mode");
    lcd.print(5,1,"Selected");
    menu=1;
    break;
  case 2:{
    lcd.clear();
    lcd.print(3,0,"Manual Mode");
    menu=0;
    break;
void loop(){
error:
Arduino: 1.8.13 (Mac OS X), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from /Users/oveya/Documents/Arduino/libraries/blynk-library-master/src/WidgetLED.h:13:0,
                 from /Users/oveya/Documents/Arduino/libraries/blynk-library-master/src/BlynkWidgets.h:10,
                 from /Users/oveya/Documents/Arduino/libraries/blynk-library-master/src/BlynkSimpleEsp8266.h:102,
                 from /Users/oveya/Downloads/instructables_water_flow_08_01_2017/instructables_water_flow_08_01_2017.ino:23:
/Users/oveya/Downloads/instructables_water_flow_08_01_2017/instructables_water_flow_08_01_2017.ino: In function 'void BlynkWidgetWrite6(BlynkReq&, const BlynkParam&)':
/Users/oveya/Documents/Arduino/libraries/blynk-library-master/src/Blynk/BlynkWidgetBase.h:60:33: error: 'class WidgetRTC' has no member named 'onWrite'
     BLYNK_WRITE(pin) { (widget).onWrite(request, param); }
/Users/oveya/Downloads/instructables_water_flow_08_01_2017/instructables_water_flow_08_01_2017.ino:37:1: note: in expansion of macro 'BLYNK_ATTACH_WIDGET'
/Users/oveya/Documents/Arduino/libraries/blynk-library-master/src/Blynk/BlynkWidgetBase.h: In instantiation of 'BlynkAttachWidgetHelper::BlynkAttachWidgetHelper(T&, uint8_t) [with T = WidgetRTC; uint8_t = unsigned char]':
/Users/oveya/Downloads/instructables_water_flow_08_01_2017/instructables_water_flow_08_01_2017.ino:37:1:   required from here
/Users/oveya/Documents/Arduino/libraries/blynk-library-master/src/Blynk/BlynkWidgetBase.h:53:9: error: 'class WidgetRTC' has no member named 'setVPin'
         widget.setVPin(vPin);
Multiple libraries were found for "BlynkSimpleEsp8266.h"
 Used: /Users/oveya/Documents/Arduino/libraries/blynk-library-master
 Not used: /Users/oveya/Documents/Arduino/libraries/Blynk
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
