I’m trying to upload this sketch to my esp8266, but the compiler shows this error:
In file included from C:\Users\mus76\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:17:0,
from C:\Users\mus76\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from C:\Users\mus76\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp8266.h:24,
from C:\Users\mus76\Documents\Arduino\hc04_simpletimer\hc04_simpletimer.ino:2:
C:\Users\mus76\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:36:21: error: redefinition of 'class BlynkTimer'
#define SimpleTimer BlynkTimer
C:\Users\mus76\Documents\Arduino\libraries\SimpleTimer/SimpleTimer.h:10:7: note: in expansion of macro 'SimpleTimer'
class SimpleTimer {
C:\Users\mus76\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:36:21: error: previous definition of 'class BlynkTimer'
C:\Users\mus76\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:41:7: note: in expansion of macro 'SimpleTimer'
class SimpleTimer {
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
My sketch is here:
char ssid[] = "Your SSID";
char pass[] = "Your password";
#define ECHOPIN 12 //Echo to pin D6
#define TRIGPIN 14 //Trig to pin D5
unsigned long previousMillisA = 0;
unsigned long previousMillisB = 0;
const long intervalA = 2;
const long intervalB = 10;
const long intervalC = 1000; // cycle period SimpleTimer timer;
WidgetLCD lcd(V2);
pinMode(ECHOPIN, INPUT);
pinMode(TRIGPIN, OUTPUT);
void sendUptime() {
unsigned long currentMillisA = millis();
unsigned long currentMillisB = millis();
if (currentMillisB - previousMillisB >= intervalC)
previousMillisB = currentMillisB;// trebuie
if (currentMillisA - previousMillisA <= intervalA)
previousMillisA = currentMillisA;
digitalWrite(TRIGPIN, LOW);
else {
digitalWrite(TRIGPIN, HIGH);
if (currentMillisA - previousMillisA >= intervalB)
{ digitalWrite(TRIGPIN, LOW);
float distance = pulseIn(ECHOPIN, HIGH);
distance= distance/50;
Serial.println(distance);
lcd.clear(); //Use it to clear the LCD Widget
lcd.print(0, 0, distance);
I’ve followed this post https://community.blynk.cc/t/error-compiling-for-board-nodemcu-1-0-esp-12e-module/24476, and updated my blynk libraries.
Same difference.
Thanks in advance.
