Thanks Pete,
That took the upload a lot further but another error message came up …
I have coppied the last pages of the error code.
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:196:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_DATABUF_TCP_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:197:45: error: 'LAST_PARAM' was not declared in this scope
commDrv.sendBuffer(&sock, sizeof(sock), LAST_PARAM);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:197:45: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp: In static member function 'static bool ServerDrv::insertDataBuf(uint8_t, const uint8_t*, uint16_t)':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:217:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
WAIT_FOR_SLAVE_SELECT();
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:206:50: error: 'LAST_PARAM' was not declared in this scope
commDrv.sendParam((uint8_t*)&dns_server2, 4, LAST_PARAM);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:206:50: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static int8_t WiFiDrv::disconnect()':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:226:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:219:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(INSERT_DATABUF_CMD, PARAM_NUMS_2);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:221:47: error: 'LAST_PARAM' was not declared in this scope
commDrv.sendBuffer((uint8_t *)data, _len, LAST_PARAM);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:228:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(DISCONNECT_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:230:22: error: 'DUMMY_DATA' was not declared in this scope
uint8_t _dummy = DUMMY_DATA;
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:221:47: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp: In static member function 'static bool ServerDrv::sendUdpData(uint8_t)':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:243:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:230:22: note: suggested alternative: 'SPI0_DATA'
SPI0_DATA
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:231:35: error: 'LAST_PARAM' was not declared in this scope
commDrv.sendParam(&_dummy, 1, LAST_PARAM);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:231:35: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static uint8_t WiFiDrv::getConnectionStatus()':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:248:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:245:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(SEND_DATA_UDP_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:246:44: error: 'LAST_PARAM' was not declared in this scope
commDrv.sendParam(&sock, sizeof(sock), LAST_PARAM);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:246:44: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp: In static member function 'static bool ServerDrv::sendData(uint8_t, const uint8_t*, uint16_t)':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:269:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:251:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_CONN_STATUS_CMD, PARAM_NUMS_0);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static uint8_t* WiFiDrv::getMacAddress()':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:269:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:271:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(SEND_DATA_TCP_CMD, PARAM_NUMS_2);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:273:46: error: 'LAST_PARAM' was not declared in this scope
commDrv.sendBuffer((uint8_t *)data, len, LAST_PARAM);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:272:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_MACADDR_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:273:46: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp: In static member function 'static uint8_t ServerDrv::checkDataSent(uint8_t)':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:302:3: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:274:22: error: 'DUMMY_DATA' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:274:22: note: suggested alternative: 'SPI0_DATA'
SPI0_DATA
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:275:35: error: 'LAST_PARAM' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:275:35: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static char* WiFiDrv::getCurrentSSID()':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:309:5: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:304:3: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(DATA_SENT_TCP_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:305:42: error: 'LAST_PARAM' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\server_drv.cpp:305:42: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:312:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_CURR_SSID_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:314:22: error: 'DUMMY_DATA' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:314:22: note: suggested alternative: 'SPI0_DATA'
SPI0_DATA
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:315:35: error: 'LAST_PARAM' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:315:35: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static uint8_t* WiFiDrv::getCurrentBSSID()':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:332:5: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:335:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_CURR_BSSID_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:337:22: error: 'DUMMY_DATA' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:337:22: note: suggested alternative: 'SPI0_DATA'
SPI0_DATA
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:338:35: error: 'LAST_PARAM' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:338:35: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static int32_t WiFiDrv::getCurrentRSSI()':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:353:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:356:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_CURR_RSSI_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:358:22: error: 'DUMMY_DATA' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:358:22: note: suggested alternative: 'SPI0_DATA'
SPI0_DATA
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:359:35: error: 'LAST_PARAM' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:359:35: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static uint8_t WiFiDrv::getCurrentEncryptionType()':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:376:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:379:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_CURR_ENCT_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:381:22: error: 'DUMMY_DATA' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:381:22: note: suggested alternative: 'SPI0_DATA'
SPI0_DATA
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:382:35: error: 'LAST_PARAM' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:382:35: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static int8_t WiFiDrv::startScanNetworks()':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:400:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:403:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(START_SCAN_NETWORKS, PARAM_NUMS_0);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static uint8_t WiFiDrv::getScanNetworks()':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:425:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:428:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(SCAN_NETWORKS, PARAM_NUMS_0);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static uint8_t WiFiDrv::getEncTypeNetowrks(uint8_t)':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:453:10: warning: converting to non-pointer type 'uint8_t {aka unsigned char}' from NULL [-Wconversion-null]
return NULL;
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:455:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:458:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_IDX_ENCT_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:460:40: error: 'LAST_PARAM' was not declared in this scope
commDrv.sendParam(&networkItem, 1, LAST_PARAM);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:460:40: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static int32_t WiFiDrv::getRSSINetoworks(uint8_t)':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:478:10: warning: converting to non-pointer type 'int32_t {aka long int}' from NULL [-Wconversion-null]
return NULL;
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:481:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:484:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_IDX_RSSI_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:485:40: error: 'LAST_PARAM' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:485:40: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static uint8_t WiFiDrv::reqHostByName(const char*)':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:501:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:504:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(REQ_HOST_BY_NAME_CMD, PARAM_NUMS_1);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:505:63: error: 'LAST_PARAM' was not declared in this scope
commDrv.sendParam((uint8_t*)aHostname, strlen(aHostname), LAST_PARAM);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:505:63: note: suggested alternative: 'LAST_ACK'
LAST_ACK
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static int WiFiDrv::getHostByName(arduino::IPAddress&)':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:528:2: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:530:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_HOST_BY_NAME_CMD, PARAM_NUMS_0);
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp: In static member function 'static char* WiFiDrv::getFwVersion()':
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:566:4: error: 'WAIT_FOR_SLAVE_SELECT' was not declared in this scope
C:\Users\Billy P\Documents\Arduino\libraries\WiFi_Link\src\utility\wifi_drv.cpp:568:5: error: 'commDrv' was not declared in this scope
commDrv.sendCmd(GET_FW_VERSION_CMD, PARAM_NUMS_0);
exit status 1
Error compiling for board Arduino Uno WiFi Rev2.
