Error compiling ESP8266 direct connect sketch
Hi all :smile:
Loving the Blynk project :smiley:
I am trying to test out the direct connect option - but when I try to compile I get an error saying that the ESP8266WiFi.h is not found? - Where should it be located?
Thanks in advance!
Double check that you have selected the esp8266 as your board type.
I make that same mistake when working on a project way to late. I still had uno selected from a previous project. I was getting the same error.
Thanks! That solves that - although I’m rather confused. I want to connect to the esp8266 directly - access point mode I guess?.. But I still want to use a arduino. The direct connect sketch needs to be run on the esp8266 I guess?
How would I go about this?
Thanks :slight_smile:
is this possible guys? Thanks :slight_smile:
Not it’s not currently possible (at least not easy)
OK thank you. What is the easiest method to set up something as a AP? Direct connect to the ESP8266 with no arduino I guess?
Cheers :smile:
