Energy monitor does not work
hi
blynk does connect but if i use emonlib with it emonlib does not read any sensors and the code does not continue like if use Serial.print it does not print anything in the serial monitor. if i use the emonlib without blynk it work fine also the bylink without the emonlib works fine but together there is a problem
here is the code
#include "EmonLib.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
EnergyMonitor emon;
EnergyMonitor emon1;
#define vCalibration 69.9
#define currCalibration 0.50
#define vCalibration1 83.3
#define currCalibration1 0.50
#define BLYNK_TEMPLATE_ID "xxx"
#define BLYNK_TEMPLATE_NAME "Quickstart Template"
#define auth "xxxxx"
char ssid[] = "xxxx";
char pass[] = "xxxx";
float kWh = 0;
float kWh1 = 0;
float kWhtotal = 0;
unsigned long lastmillis = millis();
void myTimerEvent()
  emon.calcVI(20, 2000);
  emon1.calcVI(20, 2000);
  yield();
  Serial.print("Vrms: ");
  Serial.print(emon.Vrms, 2);
  Blynk.virtualWrite(V1, emon.Vrms);
  emon.voltage(15, vCalibration, 1.7); // Voltage: input pin, calibration, phase_shift
  emon.current(34, currCalibration); // Current: input pin, calibration.
  emon1.voltage(35, vCalibration1, 1.7); // Voltage: input pin, calibration, phase_shift
  emon1.current(34, currCalibration1); // Current: input pin, calibration.
  timer.setInterval(5000L, myTimerEvent);
