I thought it would be good if our widget button could be enabled and disabled by program, as we needed it, indicating it on the screen of our phone with a color change, enabled with the color we have chosen, and disabled with a gray color, for example. .
Widgets are always “enabled”… but in your code you can set flags or parameters that determine whether to acknowledge, for example a button press, or not, depending on your other code parameters… lots of discussion and examples about this already in this forum.
