Hello , not receiving email logic seems right all messages are output to to V1 thank you
BLYNK_WRITE(V1)
if (!strcmp("temp",param.asStr())){
DHT dht; //create a DHT class object
Blynk.virtualWrite(V1, "\n reading tmp \n");
int chk = dht.readDHT11(DHT11_Pin); //read DHT11 and get a return value. Then determine whether data read is normal according to the return value.
if(chk == DHTLIB_OK){
Blynk.virtualWrite(V1, "sending email\n");
Blynk.email("leon.rosenfeild@gmail.com", " Subject: test", "My Blynk project is online.");
Blynk.virtualWrite(V2, "Temp C :",dht.temperature );
} else
Blynk.virtualWrite(V2, "failed to read");
else if (!strcmp("clear",param.asStr()))
terminal.clear();
else if (!strcmp("v",param.asStr())){
terminal.clear();
Blynk.virtualWrite(V1,"Blynk v ", BLYNK_VERSION, ": Device started\n");
Blynk.virtualWrite(V1,"-------------\n");
@sabie please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Copy and paste them if you cant find the correct characters on your keyboard.
yes all messages and temp outputs correctly . Using the cloud , originally had “test” in subject but added “subject:” as I saw in the examples , checked junk no emails also using the “free” version of Blynk does that matter?
Thanks Pete! Just added the email widget and its working! I am very impressed with Blynk thank you and your team for an excellent product! I’m a retired hardware/software engineer 42 years
@ IBM getting a life again!
Glad you’re happy with Blynk, but I’m not part of “the team”, simply one of the moderators here on the forum.
Did you ever use MQTT at Big Blue?
