Edison with SimpleTimer Problem!
When I create a Simpletimer It occoured wrong !!!
The Terminal printf some unrecgnize symbols !Look Like “**B0100000063f694 �” .
I don’t know weather it is the problem of firmware version of intel edison.When I create a new project and only write cod e to test SimpleTimer ,It does not work!
Are you using an Intel or Arduino IDE?
Paste in your sketch and format with </> if you would like us to see if you have bugs in your code.
Using Arduino IDE .I fix it a moment ago. I change the source code of SimpleTimer. I move the code of SimpleTimer’s constructor code to the begining of method SimpleTimer::setTimer .And it works !!
Maybe we can make a workaround for this, but it will be not a nice piece of code)))
Should be fixed in latest release
