Hello friends,
I had a problem with the computer and I had to upload a sketch that I was already using without problem, but when I upload the new sketch with another ID I get an error message on the serial monitor, and I can’t enable the new device with my smartphone, where am I going wrong?
This is the error message,
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.1.0 on NodeMCU
#StandWithUkraine https://bit.ly/swua
[4951] Current time: Wed Oct 5 01:20:27 2022
[4951] Connecting to blynk.cloud:443
[6832] Invalid auth token
this is my sketch
#define BLYNK_TEMPLATE_ID "xxxxxxxxx"
#define BLYNK_DEVICE_NAME "xxxxxxxx"
//#define BLYNK_DEBUG
//#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
#include "BlynkEdgent.h"
#include <AceButton.h>
using namespace ace_button;
// define the GPIO connected with Relays and switches
#define RelayPin1 12 //D6 0 V3
//#define RelayPin2 15 //
#define RelayPin2 13 //D7 100 V1
#define RelayPin3 14 //D8 0 V2
//#define SwitchPin1 10 //SD3
#define SwitchPin2 15 //D5
#define SwitchPin3 3 //RX
#define wifiLed 16 //D0
//Change the virtual pins according the rooms
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
#define VPIN_BUTTON_3 V3
//#define VPIN_BUTTON_4 V4
int toggleState_1 = 0; //Define integer to remember the toggle state for relay 1
int toggleState_2 = 0; //Define integer to remember the toggle state for relay 2
int toggleState_3 = 0; //Define integer to remember the toggle state for relay 3
//int toggleState_4 = 0; //Define integer to remember the toggle state for relay 4
void handleEvent1(AceButton*, uint8_t, uint8_t);
void handleEvent2(AceButton*, uint8_t, uint8_t);
void handleEvent3(AceButton*, uint8_t, uint8_t);
//void handleEvent4(AceButton*, uint8_t, uint8_t);
void relayOnOff(int relay){
switch(relay){
case 1:
if(toggleState_1 == 0){
digitalWrite(RelayPin1, LOW); // turn on relay 1
toggleState_1 = 1;
Serial.println("Device1 ON");
else{
digitalWrite(RelayPin1, HIGH); // turn off relay 1
toggleState_1 = 0;
Serial.println("Device1 OFF");
delay(100);
break;
case 2:
if(toggleState_2 == 0){
digitalWrite(RelayPin2, LOW); // turn on relay 2
toggleState_2 = 1;
Serial.println("Device2 ON");
else{
digitalWrite(RelayPin2, HIGH); // turn off relay 2
toggleState_2 = 0;
Serial.println("Device2 OFF");
delay(100);
break;
case 3:
if(toggleState_3 == 0){
digitalWrite(RelayPin3, LOW); // turn on relay 3
toggleState_3 = 1;
Serial.println("Device3 ON");
else{
digitalWrite(RelayPin3, HIGH); // turn off relay 3
toggleState_3 = 0;
Serial.println("Device3 OFF");
delay(100);
break;
default : break;
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
//Blynk.syncVirtual(VPIN_BUTTON_3);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
toggleState_1 = param.asInt();
if(toggleState_1 == 1){
else {
BLYNK_WRITE(VPIN_BUTTON_2) {
toggleState_2 = param.asInt();
if(toggleState_2 == 1){
else {
BLYNK_WRITE(VPIN_BUTTON_3) {
toggleState_3 = param.asInt();
if(toggleState_3 == 1){
else {
delay(100);
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(RelayPin3, OUTPUT);
// pinMode(RelayPin4, OUTPUT);
pinMode(wifiLed, OUTPUT);
pinMode(SwitchPin1, INPUT_PULLUP);
pinMode(SwitchPin2, INPUT_PULLUP);
pinMode(SwitchPin3, INPUT_PULLUP);
// pinMode(SwitchPin4, INPUT_PULLUP);
//During Starting all Relays should TURN OFF
// digitalWrite(RelayPin4, HIGH);
digitalWrite(wifiLed, HIGH);
config1.setEventHandler(button1Handler);
config2.setEventHandler(button2Handler);
config3.setEventHandler(button3Handler);
// config4.setEventHandler(button4Handler);
button1.init(SwitchPin1);
button2.init(SwitchPin2);
button3.init(SwitchPin3);
// button4.init(SwitchPin4);
BlynkEdgent.begin();
Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);
Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);
Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3);
// Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4);
//timer.setInterval(3000L, checkBlynkStatus); // check if Blynk server is connected every 3 seconds
BlynkEdgent.run();
//Manual Switch Control
button1.check();
button2.check();
button3.check();
// button4.check();
void button1Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT1");
relayOnOff(1);
Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); // Update Button Widget
void button2Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT2");
relayOnOff(2);
Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); // Update Button Widget
void button3Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT3");
relayOnOff(3);
Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); // Update Button Widget
Thanks in advanced for help me
