I’m making some test with Amazon Echo. I’m using IFTTT to easily connect the Blynk with Echo.
I connected a switch using 0 / 1 and is working correctly. I can swich on / off a device.
Now I wolud like “trigger” a MENU where I got differente options. Every option move the RGB light to a different color:
Like
1 White
2 Orange
3 Green
4 Red
How can send correctly the 1,2,3 by IFFT? is somethink I can do?
I used this setting:
URL:http://blynk-cloud.com:8080/TOKEN/pin/V10
METHOD: PUT
CONNECT TYPE: application/json
BODY… I tried [“2”] but not worked. What is the correct sintax?
