Is it possible to create widgets dynamically via some form of API?
Dynamic meaning - not have to do it from mobile app here…
There is no documented way of doing this.
In theory, if you were running a local server then you could create your own <username>.Blynk.user
file in JSON format and do it that way, but you’d need to know study the format of these files and understand the meaning of each field.
Probably not worth the effort in the end.
@PeteKnight I tried this but always have to restart server in order to sync. Is there any way to overcome this?
I have no idea, as I said, its not a documented/supported feature and not something I’ve ever tried.
Have you tried stopping and starting the app, or logging out of the app and back in again?
I will try that out. thanks!
