Duemilanove not supported? --SOLVED--
Am i forced to buy another Arduino?
I don’t see my Duemilanove in the hardware-list.
But before i buy a new arduino, please confirm (or help me)
Now i get: Uno not online… :frowning:
Look at the screenshot :wink:
OK Pavel, that’s clear :smile:
But still: on BLYNK start it says: Arduino Due is offline :frowning:
Serial monitor prints the auth token ( every six seconds)
What do i overlook ??
BTW : Greetings from Holland !
Ron.
Which example sketch are you using or how are you connected to the Internet?
But on second thought:
i own an Arduino Duemilanove , this board is completely different from an Arduino Due !!
Are you 100% sure your answer is correct ??
Regards,
Ron.
example sketch : Arduino-Serial_USB
Internetconnection: fast cable through router.
Oh, my bad @RadioRon. You are so right, Duemilanove is on ARM. We don’s support it now.
@vshymanskyy, can we give any estimates on the support?
OK.
Thanks for the quick response.
I’ll wait for @vshymanskyy 's estimate
(I guess i’ll have to order an Uno.) :wink:
RadioRon.
@Pavel, @RadioRon
Guys, there is a bit of mess here.
Duemilanove is not Due.
Due is on ARM, Duemilanove is on AVR (ATmega328).
Duemilanove is supported by the library (yaaay!) and should connect and work same way as UNO.
In the App, just select the UNO board.
Ron, maybe you forgot to run the script on your PC. Please read through instructions in the sketch :wink:
Thanks!
Confused; not being a expert, but still puzzled:
The DUE is on ARM
(“The Arduino Due is a microcontroller board based on the Atmel SAM3X8E ARM Cortex-M3 CPU”)
My Duemilanove is a simple ATmega328 ! That’s not ARM or am i wrong ?
(" The Arduino Duemilanove (“2009”) is a microcontroller board based on the ATmega168 (datasheet) or ATmega328")
So now you let me with more questions :stuck_out_tongue_winking_eye:
@RadioRon, ATmega328 is AVR, as I wrote :slight_smile:
Ron, maybe you forgot to run the script on your PC. Please check my last comment again, and read through instructions in the sketch :wink:
Ah… @vshymanskyy shares my thoughts :slight_smile:
I’m going to take a close look at this script and how to run it on my PC
Be back when ready … Thx.
@vshymanskyy @Pavel
WORKS !
Verry happy!
@vshymanskyy You we’re totally right , Stupid RadioRon forgot the script…
Thanks both for quick and helpfull support !!
RadioRon, Holland / The Netherlands.
