DSC keybus interface not work on New Blynk Iot
Thx for you!
You’re welcome bro.
Hi szenczyzoltan,
I am trying to do a project like you, use New Blynk App with DSC keybus interface, I also use the updated code above but when running the sketch, it is connecting to the blynkServer and appear " Invalid auth token".
I don’t know how to fix that, even i created a new device to get the Blynk auth token.
Please help me with this.
Thanks for the help!
Eric
Read this…
Hi PeteKnight,
Even though I already change the sketch following your post, it still displays an invalid auth token.
I am also not sure about my Blynkserver address. Do you know how to get the Blynk local server address on the New Blynk app?
Thanks for helping.
Eric
Hi Eric!
I will send you my program. I modified it a bit. I use it with a fixed IP address before the dhcp domain. It also includes inputs with negative start. It has some Blynk.logEvent.
For example, a siren or an error. It also includes outputs with positive start. Relay output with transistor. All you have to do is replace the first three lines.
TEMPLATE_ID
DEVICE_NAME
AUTH_TOKEN
Use Wemos D1 mini!
Good luck. If you have any questions, write to me.
By, Zoli.
Or send me private e-mail address!
szenczyzoltan@gmail.com
Have you been through the provisioning process via the app?
You shouldn’t need to change this, especially with Edgent.
Hi Szenczy,
Thanks for your reply,
Could you send me your program so that I can understand what problem is in my code?
Or you can send to my email address duybaophuc.nguyen@gmail.com
Thanks so much
Eric
hola me gustaria saver si alguno se ustedes tine una platilla del teclado virtual para alarma dsc.
hola pit me gustaria saver si hay alguna platilla de
un teclaco virtual para una alrma dsc.
It’s not possible to share templates in Blynk IoT
