Hi , could anyone help with the attached code.?
I feel like im close but not quite there , i can connect the Wemos D1 on the app and see a value on virtual pin 5 but it just climbs slowly , i can see the temps updates in the serial monitor ok and the connection to the blynk cloud so i must be missing something in the code in regards to the virtual pin.
Any help would be greatly appreciated.
Regards
Dave
#include <OneWire.h>
#include <Blynk.h>
char auth[] = "XXXXXXXXXXXXXXXX";
char ssid[] = "XXXXXXXXX";
char pass[] = "XXXXXXXX";
void myTimerEvent()
#define ONE_WIRE_BUS 4
DeviceAddress insideThermometer = {0x28, 0xFF, 0x7D, 0x8B, 0xB5, 0x16, 0x05, 0x74 };;
void setup(void)
Serial.println("Dallas Temperature IC Control Library Demo");
Serial.print("Locating devices...");
sensors.begin();
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
Serial.print("Device 0 Address: ");
printAddress(insideThermometer);
Serial.println();
sensors.setResolution(insideThermometer, 9);
Serial.print("Device 0 Resolution: ");
Serial.print(sensors.getResolution(insideThermometer), DEC);
Serial.println();
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
Serial.print("Temp C: ");
Serial.print(tempC);
Serial.println(DallasTemperature::toFahrenheit(tempC));
void loop(void)
Serial.print("Requesting temperatures...");
Serial.println("DONE");
printTemperature(insideThermometer);
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++)
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);
