Hello, I am French and I hope my English will be understandable.
I want to check the temperature (ds18b20) with my nodemcu and check it with Blynk.
When the temperature exceeds 82 degrees the relay closes and when the temperature drops to 72 it turns back on.The code works correctly but as soon as I add the blynk code I can’t do it anymore. The error message appears: ‘A1’ was not declared in this scope.
Thanks for your help
#include "OneWire.h"
#include "DallasTemperature.h"
char auth[] = "***";
char ssid[] = "***";
char pass[] = "****";
#define WATER_TEMP_PIN A1
#define RELAY_PIN A0
OneWire oneWire(WATER_TEMP_PIN);
bool allume = true ; // true pour cuiseurvapeur allumé, false sinon
void sendSensor()
float t = Serial.print(dTempWater); // or dht.readTemperature(true) for Fahrenheit
if (isnan(t)) {
return;
Blynk.virtualWrite(V6, t);
pinMode (RELAY_PIN, OUTPUT);
// On initialise la connexion série
delay(2000);
// On récupère la température de la sonde
double dTempWater = sensors.getTempCByIndex(0);
// On imprime la température
Serial.print("Température de l'eau: ");
Serial.println("°C");
// On attends 5 secondes
delay(5000);
if (isnan(dTempWater)) {
if (dTempWater >= 82) allume = false;}
{ if (dTempWater <= 72) allume = true;
digitalWrite(RELAY_PIN, allume);
