Domotic bedroom
hello guys, recently, i have made my domotic bedroom, but I have some problem, in the room, there are a relay shield and a lm35cz. I have problem with a relay shield. i control the relay shield by button and menu widget, when use menù blynk some times the device goes offline this is the sketch:
#define potPin  A0
#include <Ethernet.h>
 const int ledPin1 =  9;// lUME
 const int ledPin2 =  8;//  lUCE
 const int ledPin3 =  7;//  PIANTANA
 const int ledPin4 =  5;//  LAMPADA
char auth[] = "000000000000000000000000000000";
#define W5100_CS  10
#define SDCARD_CS 4
WidgetLCD lcd(V1);
  BLYNK_WRITE(V0) {
  switch (param.asInt())
    case 1: // Manuale
        break;
    case 2: // Off
      digitalWrite(ledPin1, HIGH);
      digitalWrite(ledPin2, LOW);// Relè collegato al contrario
      digitalWrite(ledPin3, HIGH);
      digitalWrite(ledPin4, HIGH);
      break;
      case 3: // SERA
      digitalWrite(ledPin1, LOW);
      digitalWrite(ledPin3, LOW);
      digitalWrite(ledPin4, LOW);
      break;
       case 4: // SERATA
      break;
       case 5: // OSPITI
    digitalWrite(ledPin2, HIGH);// Relè collegato al contrario
      break;
       case 6: // BUONANOTTE
      break;
    default:
      Serial.println("Unknown item selected");
void myTimerEvent()
   int aRead = 0;
  aRead = analogRead(potPin);
  float tempC = aRead * 0.48875;
    lcd.print(1, 0, "Temperatura");
  lcd.print(3, 1, (tempC));
  lcd.print(12,1, "°C");
  Blynk.virtualWrite(V1, millis() / 1000);
   digitalWrite(ledPin2,HIGH);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
  pinMode(SDCARD_CS, OUTPUT);
  digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
  Blynk.begin(auth);
   timer.run(); // I
do you have any advice?
Ps. thank you for your attencion, and sorry for my English!
Possibly just a flaky Ethernet shield. They are known to have connection issues.
You also seem to be missing the pinMode() for ledPin2
when i can try? the pin mode 2 is sudmitted
