Does any sensor work with Blynk?
For connecting sensors to my Raspberry Pi, does it matter which sensors I connect?
As an example, I want to make sure I get a temperature sensor that is supported since there are so many different temperature sensors out there.
Any sensor work…? If it works with the rPi, Yes.
You are only really sending the final output of the sensor, blynk has nothing to do with where or how that number(eg. temperature) is created/calculated, it only ‘knows’ that you are sending it a variable(eg. “72” on vPin1)
