Displaying Webhook GET Value to Hardware 16X2 LCD via I2C
I use NodeMCU 1.0 and Blynk webhook widget to get data from openweathermap.org, trying to display weather condition (such as temp, hum, press, weather condition, sunrise, sunset, etc) to my 16X2 LCD. I also do Json parse since the coming data is in Json format.
When I try to serial print the result for each weather condition, values come out correctly and get updated when the there is some changes based on the data coming from openweathermap.org.
But, when I try to display those value in my 16X2 LCD also, suddenly, the data displayed both on serial print and LCD, did not updated. Even the Json responses is always same since beginning.
Really appreciate for any help here.
Btw, here is my sketch:
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example shows how to fetch data using WebHook GET method
  App project setup:
    WebHook widget on V0, method: GET, url: /pin/
// Allow for receiving messages up to 512 bytes long
#define BLYNK_MAX_READBYTES 1024
#include <ArduinoJson.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3F, 16, 2);
char auth[] = "mytokenhere";
char ssid[] = "mywifihere";
char pass[] = "mypasswordhere";
String webhookdata;
int counter = 10;
String description = "";
float temperature;
int pressure;
int humidity;
float windspeed;
int winddeg;
String country;
String sunrise;
String sunset;
String city = "";
BLYNK_WRITE(V0) {
  webhookdata = param.asStr();
void getNewData() {
  if (counter == 10) {
    Serial.println("counter 10");
    counter = 0;
    Blynk.virtualWrite(V0, "http://api.openweathermap.org/data/2.5/weather?id=1860243&APPID="myAPIhere");
    Serial.println(webhookdata);
  else {
    counter++;
void splitJson() {
  const size_t bufferSize = JSON_ARRAY_SIZE(1) + JSON_OBJECT_SIZE(1) + 2*JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(4) + JSON_OBJECT_SIZE(5) + JSON_OBJECT_SIZE(6) + JSON_OBJECT_SIZE(12) + 400;
  DynamicJsonBuffer jsonBuffer(bufferSize);
  String wJson = webhookdata;
  JsonObject& root = jsonBuffer.parseObject(wJson);
  float Longitude = root["coord"]["lon"]; // 136.63
  float Latitude = root["coord"]["lat"]; // 36.59
  JsonObject& weather0 = root["weather"][0];
  int weatherID = weather0["id"]; // 801
  String Main = weather0["main"]; // "Clouds"
  String Description = weather0["description"]; // "few clouds"
  String Icon = weather0["icon"]; // "02d"
  String base = root["base"]; // "stations"
  JsonObject& main = root["main"];
  float Temperature = main["temp"]; // 18.48
  int Pressure = main["pressure"]; // 1020
  int Humidity = main["humidity"]; // 55
  int TempMin = main["temp_min"]; // 18
  int TempMax = main["temp_max"]; // 19
  int Visibility = root["visibility"]; // 10000
  float WindSpeed = root["wind"]["speed"]; // 5.1
  int WindDeg = root["wind"]["deg"]; // 10
  int CloudsAll = root["clouds"]["all"]; // 20
  long dt = root["dt"]; // 1508997600
  JsonObject& sys = root["sys"];
  int SysType = sys["type"]; // 1
  int SysID = sys["id"]; // 7567
  float SysMessage = sys["message"]; // 0.0046
  String Country = sys["country"]; // "JP"
  String Sunrise = sys["sunrise"]; // 1508965858
  String Sunset = sys["sunset"]; // 1509005000
  long id = root["id"]; // 1860243
  String City = root["name"]; // "Kanazawa-shi"
  int cod = root["cod"]; // 200
  Serial.println(City);
  Serial.println(Country);
  Serial.println(Description);
  Serial.println(Temperature);
  Serial.println(Pressure);
  Serial.println(Humidity);
  Serial.println(WindSpeed);
  Serial.println(WindDeg);
  Serial.println(Sunrise);
  Serial.println(Sunset);
  city = City;
  country = Country;
  description = Description;
  temperature = Temperature;
  pressure = Pressure;
  humidity = Humidity;
  windspeed = WindSpeed;
  winddeg = WindDeg;
  sunrise = Sunrise;
  sunset = Sunset;
void showLCD() {
  lcd.backlight();
  lcd.clear();
  lcd.home();
  lcd.setCursor(0, 0);
  lcd.print(" OpenWeatherMap");
  lcd.setCursor(0, 1);
  lcd.print(" Today Forecast");
  delay(2000);
  lcd.clear();
  lcd.print(city);
  lcd.print(", ");
  lcd.print(country);
  lcd.setCursor(0,1);
  lcd.print(description);
  delay(3000);
  lcd.clear();
  lcd.print("T:");
  lcd.print(temperature);
  lcd.print((char)223);
  lcd.print("C");
  lcd.setCursor(8, 0);
  lcd.print(" H:");
  lcd.print(humidity);
  lcd.print("%");
  lcd.print("P:");
  lcd.print(pressure);
  lcd.print(" hPa");
  delay(3000);
  lcd.clear();
  lcd.print("Wind:");
  lcd.print(windspeed);
  lcd.print(" m/s");
  lcd.setCursor(0,1);
  lcd.print("Direction:");
  lcd.print(winddeg);
  delay(3000);
  lcd.clear();
  lcd.print("Today Sunrise");
  lcd.print(sunrise);
  delay(2000);
  lcd.clear();
  lcd.print("Today Sunset");
  lcd.print(sunset);
  delay(2000);
  lcd.begin(0,2);  // sda=0 | D3, scl=2 | D4
  //Blynk.virtualWrite(V0, "https://raw.githubusercontent.com/blynkkk/blynk-library/master/extras/logo.txt");
  // You can perform HTTPS requests even if your hardware alone can't handle SSL
  // Blynk  can also fetch much bigger messages,
  // if hardware has enough RAM (set BLYNK_MAX_READBYTES to 4096)
  timer.setInterval(10000L, getNewData);
  timer.setInterval(11000L, splitJson);
  timer.setInterval(15000L, showLCD);
Thanks in advance,
Imron
Total of 15 seconds, just sitting around doing nothing, whenever your LCD print routine is called… yep, that just might cause some timeout issues with Blynk and WiFi :wink:
Use timers… not delays.
Hi Gunner. Thank you for answering. And, sorry for late respons.
The problem I am facing is, even I just adding LCD 16X2 via I2C in my sketch, somehow the webhook responses itself did not updated. But, if I remove LCD 16X2 via I2C in my sketch, webhook responses is updated from time to time.
Also, if there is LCD 16X2 via I2C and webhook widget, the device often disconnected from Blynk server. It said “Connecting to Blynk server…” on the serial monitor.
All the delays in your LCD printouts is the problem.
