* Description
* The module can give us a digital signal when the soil need watering and this output can be adjusted by the potentiometer.
* Or it can give us an analog signal of current soil moisture!
* Will use the analog signal output of this module and we will change it in percentage value.
* Finally we will use Blynk library to print the current percentage value of soil moisture into gauge
* Pin-out
* The FC-28 soil moisture sensor has four pins:
* VCC: Power
* A0: Analog Output | D0: Digital Output
* GND: Ground
* Input
* The Probe
* The sensor contains a fork-shaped probe with two exposed conductors that goes into the soil or anywhere else where the water content is to be measured.
* The Module
* The sensor also contains an electronic module that connects the probe to the nodemcu.
* The module produces an output voltage according to the resistance of the probe and is made available at an Analog Output (AO) pin.
* Output
* V0 : Blynk Virtual Pin 0
// Constants
char auth[] = "auth";
char ssid[] = "ssid";
char pass[] = "ssidPassword";
const int analogPinA0 = A0;
// Objects
// Variables
int sensorData;
int output;
void sendSensor()
sensorData = analogRead(A0); //reading the sensor on A0
if ( isnan(sensorData) ){
// Serial.println("Failed to read from Hygrometer Soil Moisture sensor!");
return;
// Serial.println(sensorData);
// When the plant is watered well the sensor will read a value 380~400, I will keep the 400
// value but if you want you can change it below.
sensorData = constrain(sensorData,400,1023); //Keep the ranges!
output = map(sensorData,400,1023,100,0); //Map value : 400 will be 100 and 1023 will be 0
// Serial.println(output);
Blynk.virtualWrite(V0, output);
WiFi.hostname("Siggy"); // all my devices have Vikings name (I know it's geek)
timer.setInterval(3000L, sendSensor);
