Um… I think I answered the first question… The battery IS connected to the Nano device at the well
The battery 12 volts goes through a step down to 5volts that is connected to board. So the voltage supplied to the board is 5v. It would be ideal to know what the battery voltage is. Does this help?
That could be taken to mean that you want to monitor the voltage at the sender end, but I don’t like to jump to conclusions.
Yes, it answers both of my questions.
The easiest solution would be to use a simple two resistor voltage divider to allow you to measure the battery voltage with one of the available analog pins on the Nano.
As these two resistors will be in series across the positive and negative terminals of the battery you’ll need to choose high resistances so that you don’t drain the battery or fry the resistors.
Thank you Pete, my main thoughts are how to be integrate a sensor into my existing Blynk program.
Jeff
It rather depends on what you do at the Nano end as far as taking the voltage readings and sending them via LoRa is concerned.
You’d then need to extract the voltage readings and send them to a virtual pin in Blynk along with your existing data. You could then add some notification functionality to warn you when the voltage drops below a certain level.
Thanks Pete:
I was thinking of sending the data (water depth, voltage) as an array from the well to ESp8266. Hopefully I can figure out how to have sketch parse the array and send it to the Blynk server.
I’d send it as either a string, with delimiters between the fields, or as a JSON object.
Hi Pete:
It’s been a while since we chatted. I hope you had a good winter. It’s spring and I’m planning on going up to the cabin. The program you helped my with (December 2021 above) worked really well last summer and actually saved us from a water break - so thanks. At the end of last year I mentioned that I thought I’d like to add a sensor to measure the voltage of the battery at the tank - as it began to fail towards the end of the season. I took your advice and learned about voltage dividers. I created one and attached it to the transmitter at the well head. The transmitter sketch works okay and displays the water depth and voltage. The problem is on the receiving end. I’ve tried to add code to receive, parse and display the voltage. But it doesn’t work I just get a reading of “0”. I have avoided having to rewrite the code to send and receive the data as an array or structure as I’m not quite comfortable with them - so I thought I’d try a simple solution. Obviously it didn’t work. Is there a way of getting the voltage to display along with the water depth and send it along to Blynk2? I’ll attach the transmitter sketch followed by the receiver sketch.
TRANSMITTER SKETCH
* Credits to VDEngineering video for the Kalman filter algorithm:
* https://www.youtube.com/watch?v=ruB917YmtgE
#include <Wire.h>
#include <LoRa.h>
LiquidCrystal_I2C lcd(0x3F, 16, 2);
const int echo = 8;
const int trig = 7;
const int maxdist = 450;
const float mindist = 2.5;
//const int R1 = 30000;
//const int R2 = 7500;
double kalman(double U);
double kalman(double U) {
static const double R = 60;
static const double H = 1.00;
static double Q = 10;
static double P = 0;
static double U_hat = 0;
static double K = 0;
K = P * H / (H * P * H + R);
U_hat += +K * (U - H * U_hat);
P = (1 - K * H) * P + Q;
return U_hat;
double distance, duration, voltage;
lcd.begin();
lcd.backlight();
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
pinMode(A0, INPUT);
while (!Serial)
Serial.println("LoRa Receiver");
if (!LoRa.begin(433E6)) {
Serial.println("Starting LoRa failed!");
while (1)
LoRa.setSpreadingFactor(10);
LoRa.setSignalBandwidth(62.5E3);
LoRa.crc();
digitalWrite(trig, LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(10);
duration = pulseIn(echo, HIGH);
distance = (duration * .0133) / 2;
// Define voltage divider resistors
int value = 0;
float R1 = 30000.0;
float R2 = 7500.0;
//Read voltate - may have to adjust 5.00 to input voltage on Vin
value = analogRead(A0);
voltage = value * (5.10 / 1024) * ((R1 + R2) / R2); // should be 5 volts, but adjusted for voltage reading at nano 5v pin
// Kalman filter for distance measurement
double fildist = kalman(distance);
Serial.print("Water is down: ");
Serial.print(fildist);
Serial.print(" inches, Voltage is: ");
Serial.print(voltage);
Serial.println(" V");
delay(500);
// Send packet
LoRa.beginPacket();
LoRa.print(fildist);
LoRa.print(",");
LoRa.print(voltage);
LoRa.endPacket();
delay(200);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Water:");
lcd.print(fildist);
lcd.print(" in");
lcd.setCursor(0, 1);
lcd.print("Voltage:");
lcd.print(voltage);
lcd.print(" V");
if (fildist <= 25) {
digitalWrite(5, LOW);
digitalWrite(5, HIGH);
RECEIVER SKETCH
For this example you'll need the following library:
1) Arduino-LiquidCrystal-I2C-library: https://github.com/fdebrabander/Arduino-LiquidCrystal-I2C-library
2) Blynk Library 0.6.1 (if usimg Legacy or latest if using IoT): https://github.com/blynkkk/blynk-library
Conncetions:
D0 (GPIO16) -> RST Pin on LoRa Rx module
D1 (GPIO5) -> LED on U3 connector?
D2 (GPIO4) -> DIO0 Pin on LoRa Rx Module
D3 (GPIO0) -> SDA Pin on OLED Display
D4 (GPIO2) -> SCL Pin on OLED Display
D5 (GPIO14) -> SCK pin on LoRA Rx module
D6 (GPIO12) -> MISO pin on LoRA Rx module
D7 (GPIO13) -> MOSI pin on LoRA Rx module
D8 (GPIO15) -> nSS pin on LoRA Rx module
#include <LoRa.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define I2C_SDA 0 // GPIO0 = D3 - redefining I2C pins as D1 is needed by LoRa unit
#define I2C_SCL 2 // GPIO2 = D4
#define ss 15 // GPIO15 = D1
#define rst 16 // GPIO16 = D0
#define dio0 4 // GPIO4 = D2
int LEDPin=5; //Relay and LED pin
int adjustment;
int adjusted_reading;
int tank_to_read;
int voltage;
const int ledPin = 5; // GPIO5 = D1 - warning light that water has dropped beyond preset level
char auth[] = "ZFiawkv0a-UnC_tXeO3Ir0n_FRhEXy1v"; //Enter the Auth code which was send by Blink
char ssid[] = "XXXXXXXXXXXXX"; //Enter your WIFI Name kuggle's_condo_2
char pass[] = "XXXXXXXXXXXXXX"; //Enter your WIFI Password
int wifi_connect_count = 0; // Keep track of how many times we've tried to connect to the WiFi
int wifi_connect_max_retries = 20; // Specify how many attempts we will have at connecting to the WiFi
bool sync_completed = false; // Flag to track when BLYNK_WRITE(V1) has completed
pinMode(ledPin, OUTPUT);
Wire.begin(I2C_SDA, I2C_SCL); // Updated from deprecated wire.pins(sda,scl) command
Serial.begin(9600); // Native baud rate for the NodemCU
lcd.begin(); // iInit the LCD for 16 chars 2 lines
lcd.backlight(); // Turn on the backligt (try lcd.noBaklight() to turn it off)
delay (1000);
Serial.println("LoRa Receiver ");
LoRa.setPins(ss, rst, dio0);
delay(2000);
Serial.println("Restarting ESP...");
ESP.restart(); // Restart the ESP
Serial.println("LoRa Started");
lcd.clear();
lcd.print("Waiting");
LoRa.crc();
WiFi_Connect();
Blynk.config(auth);
send_to_blynk(); // Connect to Blynk then sync the segmented switch at startup
timer.setInterval( 1 * 1000L, take_a_reading); // Existing timer
timer.setInterval(1 * 60 * 1000L, check_connections); // Check that we have a WiFi connection every 1 minute
timer.setInterval(2 * 60 * 1000L, send_to_blynk); // send data to Blynk every 2 minutes (180,000 m/s)
void take_a_reading()
int packetSize = LoRa.parsePacket();
int reading = LoRa.parseInt();
if (packetSize)
adjusted_reading = (reading - adjustment);
Serial.print("Selected tank = ");
Serial.println(tank_to_read);
Serial.print("Actual reading = ");
Serial.println(reading);
Serial.print("Adjustment factor = ");
Serial.println(adjustment);
Serial.print("Adjusted reading = ");
Serial.println(adjusted_reading);
Serial.print("Voltage = ");
Serial.println(voltage);
lcd.setCursor(0, 0); //First line
lcd.print(adjusted_reading);
lcd.print(" inches");
lcd.setCursor(0, 1); //Second line
lcd.print(voltage);
if (adjusted_reading >=28 ) //ALARM
digitalWrite(LEDPin,HIGH); //ALARM
if(adjusted_reading >=28)
Blynk.notify("water level has dropped below 28 inches");
timer.setTimeout(1600L, [](){
// Blynk.email("jgroberm@shaw.ca", "water level has dropped below 28 inches");
else {
digitalWrite(LEDPin,LOW); // play tone of 400Hz for 500 ms
void send_to_blynk()
if (WiFi.status() == WL_CONNECTED)
Serial.println ("Connecting to Blynk");
Blynk.connect();
if (Blynk.connected())
Serial.println ("Connected");
Blynk.syncVirtual(V1); // force the server to send the latest value for the segmented switch
while (!sync_completed) // Wait until BLYNK_WRITE(V1) has completed
take_a_reading(); // take a reading from the tank indicated by the segmented switch
Blynk.virtualWrite(V0, adjusted_reading); // To Display Widget
Blynk.virtualWrite(V1, voltage); // send voltage to Blynk
Blynk.disconnect();
Serial.println ("Blynk Disconnected");
Serial.println (">>>>>>>>>>>> Unable to connect to Blynk <<<<<<<<<<<<");
// we get here if we there is no WiFi connection
Serial.println (">>>>>>>>>>>> No WiFi Connection, so Blynk connection not attempted <<<<<<<<<<<<");
BLYNK_WRITE(V1) // Segmented switch to select tank
Serial.println("BLYNK_WRITE(V1) Executed");
tank_to_read = param.asInt();
switch (tank_to_read)
case 1:
adjustment = 0;
sync_completed = true;
break;
case 2:
adjustment = 13;
break;
case 3:
adjustment = 15;
break;
case 4:
adjustment = 12;
break;
void check_connections()
if (WiFi.status() != WL_CONNECTED)
WiFi_Connect();
Serial.println(F(">>>> WiFi checked - all good <<<<"));
void WiFi_Connect() // New functon to handle the connectuon to the WiFi network
wifi_connect_count=0; // reset the counter
Serial.println(F("Connecting to WiFi"));
WiFi.begin(ssid, pass); // connect to the network
while (WiFi.status() != WL_CONNECTED && wifi_connect_count < wifi_connect_max_retries) // Loop until we've connected, or reached the maximum number of attemps allowed
delay(500);
wifi_connect_count++;
Serial.print(F("WiFi connection - attempt number "));
Serial.println(wifi_connect_count);
WiFi.mode(WIFI_STA);
Serial.println(F("Wi-Fi CONNECTED"));
Serial.println();
Serial.println(F(">>>>>>>>>>>> Unable to connect to WiFi <<<<<<<<<<<<"));
I don’t see any evidence of parsing the incoming data to extract the voltage reading. You’re using parseInt on the incoming data to extract the water level reading…
but there is no code to extract the voltage from the incoming data.
can you give me a hint how to proceed parsing it?
I don’t really know, I’m not familiar with the library you’re using and how it handles the data it receives.
The parseInt command is normally used to parse the incoming data from serial data streams into integer values.
If it works the same way with the LoRa data then adding:
int voltage = LoRa.parseInt();
immediately after:
may work.
Thanks Pete. I"ll give it a shot and try a few other things and let you know what I get.
Hi Pete:
Well… Now I get reading, but there a string of random two digit reading that have no relation to the voltage… I’ve tried a bunch of things, but not getting anywhere…
Details?
Okay a dumb question… If I make the suggested changes so that now I have:
Won’t the value for the voltage and water depth be the same?
How can I get the program to divide the incoming data back into two separate values (depth and voltage)?
Right now the value reading on the serial monitor is 52 with the battery disconnected. It doesn’t change on the receiver serial monitor when connected.
If it works the way I suspect then the parseInt command finds the first numeric value and stores that in the variable reading.
Calling parseint again might then move on from that pointer position and find the next numeric value and store it in the variable voltage.
But, as I said, that’s just a guess and I’m not familiar with the library you are using.
I suggest you read-back through your last few posts and ask yourself if I, or anyone else, could reasonably be expected to make any sense of them.
Statements like…
tells me nothing about what you are actually seeing in your serial monitor and how it relates to the values being fed-in at the transmitter end.
At the very least, you need to be posting the serial outputs from your transmitter and receiver outputs.
will do tomorrow.
Thanks Pete.
Hi Pete:
Okay. Again, here is the Transmitter sketch:
#include <Wire.h>
#include <LoRa.h>
const int echo = 8;
const int trig = 7;
return U_hat;
lcd.begin();
lcd.backlight();
pinMode(A0, INPUT);
while (!Serial)
while (1)
LoRa.crc();
int value = 0;
float R1 = 30000.0;
float R2 = 7500.0;
delay(500);
// Send packet
LoRa.beginPacket();
LoRa.print(",");
LoRa.endPacket();
delay(200);
lcd.clear();
lcd.print(fildist);
lcd.print(" in");
lcd.print(voltage);
lcd.print(" V");
Here is the transmitter output on the serial monitor:
LoRa Receiver
Water is down: 0.00 inches, Voltage is: 5.55 V
Water is down: 9.16 inches, Voltage is: 5.53 V
Water is down: 22.12 inches, Voltage is: 5.53 V
Water is down: 34.19 inches, Voltage is: 5.55 V
Water is down: 43.59 inches, Voltage is: 5.48 V
Water is down: 50.25 inches, Voltage is: 5.53 V
And here’s the receiver sketch::
Conncetions:
#include <LoRa.h>
#include <Wire.h>
int adjustment;
int tank_to_read;
int voltage;
char ssid[] = "kuggle's_condo_2"; //Enter your WIFI Name kuggle's_condo_2
char pass[] = "jakesnak"; //Enter your WIFI Password
delay (1000);
delay(2000);
lcd.clear();
LoRa.crc();
WiFi_Connect();
Blynk.config(auth);
if (packetSize)
lcd.print(voltage);
else {
Blynk.connect();
Blynk.disconnect();
case 1:
adjustment = 0;
break;
case 2:
adjustment = 13;
break;
case 3:
adjustment = 15;
break;
case 4:
adjustment = 12;
break;
WiFi_Connect();
delay(500);
Serial.println();
and here’s the output from the receiver sketch:
Adjustment factor = 0
Adjusted reading = 64
voltage51
Selected tank = 0
Actual reading = 64
voltage59
Selected tank = 0
Actual reading = 64
voltage67
any help will be most gratefully accepted.
I don’t understand what I’m seeing here.
Your transmitter code takes a reading around every 700ms (two delays in your void loop of 500 and 200ms).
The output seems to show that the water level has dropped around 10 inches between each reading, so 50 inches over around 3.5 seconds.
As you’ve not included any timestamps on your transmit or receive serial output I have no idea what the last data sent from the transmitter was, when a value is seen at the receiver.
How can we make any sense of such rapidly changing values and unsynchronised serial outputs?
I would have thought that if these values are changing so rapidly you would have taken the sensible approach and sent some static dummy values from the transmitter so that the results are received at the receiver can be compared to these static values.
It doesn’t seem to make any sense to be sending float values, then using the parseInt function to extract an integer value from these. Wouldn’t it make sense top multiply the results by 100 before transmitting them?
Also, could you please change the code of your transmitter so that it says transmitter rather than receiver.
I’ll do as you suggest. You never mentioned anything about the voltage data. Any thoughts on why it isn’t being parsed correctly?? Also the receiver and transmitter are static, so there should be no difference in the ultrasonic or voltage readings.
