Disconnecting from device
hello … i’ve connected my esp8266 to blynk app and it says that my device is online and i tried many instructions and it works … but sometimes i get disconnected from the server for a reason i don’t know . it says my device offline and then trining to reconnect to the server … it take a few seconds to reconnect again … but why it happens?
37 reasons which are specific to your hardware and sketch.
@Costas and what are these 37 reasons?
@Mohamed_Tantawy and what is your hardware and sketch?
@Costas hardware is esp 8266 and the sketch is reading the temprature using DHT11 using blynk’s example
Which one?
Paste your formatted sketch.
And your sketch?
sorry but what do u mean by sketch ? the code?
Yes and which version of ESP8266 do you have?
Node MCU
and that’s the code
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  You can send/receive any data using WidgetTerminal object.
  App project setup:
    Terminal widget attached to Virtual Pin V1
#include <DHT.h>
char auth[] = "*****************************";
char ssid[] = "GoldeN";
char pass[] = "assd203020";
#define DHTPIN 2          // What digital pin we're connected to
#define DHTTYPE DHT11     // DHT 11
//#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h =dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V1);
//Blynk.virtualWrite(V5,5);
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
BLYNK_WRITE(V1)
  pinMode(15,OUTPUT);
String val;
   // Send it back
   // terminal.print("You said:");
  //  terminal.write(param.getBuffer(), param.getLength());
    terminal.println();
     val=param.asStr();
   //  Serial.println(val);
     if(val=="led1")
        digitalWrite(15,1);
      }else {digitalWrite(15,0);}
  // Ensure everything is sent
  terminal.flush();
  Serial.begin(230400);
  // This will print Blynk Software version to the Terminal Widget when
  // your hardware gets connected to Blynk Server
//  terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
//  terminal.println(F("-------------"));
//  terminal.println(F("Type 'Marco' and get a reply, or type"));
//  terminal.println(F("anything else and get it printed back."));
  terminal.flush();
   dht.begin();
@Mohamed_Tantawy you said you were using Blynk’s DHT11 sketch. You have modified the sketch.
It’s normal, but not compulsory, to set pinMode in setup().
I have never tried it within a BLYNK_WRITE function but I would move it to setup().
String val; will not pick up details from the Terminal (see Terminal sketch for procedure)
Do you have V5 and V6 set to PUSH in your project?
Reasons 1 to 37 for disconnects:
  1. Bad code
This may not affect your connection… but the DHT11 is notoriously slow, as it generally take 2-5 seconds to process a new signal. No sense in a 1 second polling for it… try 5 seconds instead.
