Is there a way to stop the devices going into wifi blocking mode when it cant find the wifi?
the reason I ask is I have long rang devices that don’t need wifi when in the paddock just the first enrolment stage. I find the devices are enrolling fine but as soon as I take them were there is no wifi they loop looking for blynk cloud.
Wifi can’t block the loop, but internet loss does. There is a big difference because you may be connected to WIFI without internet. But if you have no WIFI it is clear that no Internet also.
I don’t know what is your code but I believe that the loss of internet is the blocking one and not loss of WIFI . If you use (blynk.begin), you should replace and try blynk.config with blynk.connect and do you WIFI connection only once in the Setup not in the main loop…
