I need help finding a way to disabling the ability to activate V10 after it is initially activated, until V11 is activated. This way it is not activated twice and can only be activated from its original position. I’m creating a gas valve that will open the valve and start igniter with one button, and then close the gas valve with another button. Thank you for your assistance as I have tried to find information on this for some time.
#define PIN 14
#define PIN 12
#define PIN 13
char auth[] = "Auth Code";
char ssid[] = "LOGIN";
char pass[] = "PASS";
const int valveOpen = 14;
const int igniterOn = 12;
const int valveClosed = 13;
void STOP_Motor()
digitalWrite(valveClosed, LOW);
digitalWrite(valveOpen, LOW);
digitalWrite(igniterOn, LOW);
//DISABLE SECOND BUTTON PRESS UNTIL BUTTON2 (EXTINGUISH) IS ACTIVATED
BLYNK_WRITE(V10) //Button Widget is writing to pin V10
//Opens valve and ignites gas if V10 pressed, disengages at 2.5s
int pinData = param.asInt();
if (pinData == 1)
digitalWrite(valveOpen, HIGH);
digitalWrite(igniterOn, HIGH); //Igniter turns on
timer.setTimeout(2500L, STOP_Motor); // Stops motor at 2.5seconds
BLYNK_WRITE(V11) //Button Widget closes the valve
//Activates motor for 2.5 seconds and closes valve
if (pinData == 1)
digitalWrite(valveClosed, HIGH);
pinMode(14, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
digitalWrite(14,LOW);
digitalWrite(12,LOW);
digitalWrite(13,LOW);
Perfect. I got it to work. Thank you for your assistance!! Now I just have to figure out how to save the flag and not have it reset when the board accidently disconnects.
Below is the updated code for anyone who might be interested:
#define PIN 14
#define PIN 12
#define PIN 13
int motorInitiated = 0;
void STOP_Motor()
if (pinData == 1 && motorInitiated == 0)
motorInitiated++; // Sets motor Initiated to 1
if (pinData == 1)
motorInitiated = 0;
Blynk.virtualWrite(V20, motorInitiated); //write value to server
if (pinData == 1)
motorInitiated = 0;
BLYNK_WRITE(V20) //Refresh motorInitated from server
motorInitiated = param.asInt();
BLYNK_CONNECTED() {
Blynk.syncVirtual(V20);
