HW: Node MCU esp32s
Phone: Xperia X Compact
Blynk: 0.6.6 I think
I am trying to write a program that would open a PNP transistor connected to pin 0 for .75 seconds every time a button in the app is pressed, no matter how long the button is pressed for.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "MyToken";
char ssid[] = "MySSID";
char pass[] = "MyPSSWRD";
unsigned long currentTime = 0;
const long PWRPress = 750;
unsigned long timePressed = 0;
int V1Value = 0;
bool finishedness = HIGH;
BLYNK_WRITE(V1)
V1Value = param.asInt();// assigning incoming value from pin V1 to a variable
Serial.print("V1 value is:");
Serial.println(V1Value);
if (V1Value == 1 && finishedness == HIGH){
Serial.println("Turning relay on");
digitalWrite(PWRpin, LOW);
timePressed = millis();
finishedness = LOW;
digitalWrite(PWRpin, HIGH);
//Remember to avoid delay() function!
currentTime = millis();
if( currentTime >= timePressed + PWRPress && finishedness == LOW){
Serial.println("Turning relay off");
The board sends the value of V1 every time the value changes just as it should, but it doesn’t open the transistor. I have already concluded that the hardware works, because the basic blynk example where the app controls a pin directly does trigger the transistor. Why is the digitalWrite not working?
You title is misleading… BLYNK_WRITE() functions just fine… it is whatever you are doing once it grabs the widgets state that is your issue.
We don’t really teach programming here, but I would suggest you keep your void loop() clear of extraneous code and handle your “timed” GPIO process differently.
Perhaps using a BlynkTimer process to handle the timing?
BLYNK_WRITE(V1) {
if (param.asInt()) { // If receiving a 1
digitalWrite(PWRpin, HIGH); // toggle pin HIGH
timer.setTimeout(750L, []() { // toggle pin LOW 0.75 seconds later
Thank you for the suggestion. However, my problem is that the digitalWrite inside the BLYNK_WRITE function does not set the pin to LOW. Because I need to control a PNP transistor, the “off” state is actually HIGH on pin 0 and the “on” is LOW on pin 0. Is there anything I could do to fix that?
Yes, but as you can see I already have a digitalWrite(PWRpin, LOW) inside the BLYNK_WRITE function and it does not work. When I press the button in the app, the board sends all the serial messages (“V1 value is:1”, “Turning relay on”, “Turning relay off”), but it does not actually turn the relay on and off, the value on pin 0 always stays on HIGH no matter what.
I tried the exact same HW configuration in some other programs and the same digitalWeite worked. The only difference is that in those other programs I did not use the BLYNK_WRITE function.
Thanks, that might be it! I wrote this thing quite late in the night and it didn’t even cross my mind that I’d be missing something so simple. Consider this solved.
