I’ve made a project with esp8266 (Wemos D1 mini) and Blynk Interface to read a water boiler temperature and control 2 electro valve, one for closing one water circuit and second to open another water circuit.
I need some help, if I read the temperature and set a valve to be closed when temperature is above 40 degree, the command for valve is oscillating on/off because the value of temperature is oscillating around 40 degree.
There is a any possibility to remove the output oscillation because temperature value is oscillate ? From coding ?
