Digital output getting active at powering up ESP
Lots of examples if you search.
This probably isn’t the best example, but it’s one of the first I came across…
In your example you are using pin D7, which is GPIO13
This example uses GPIO2, which is pin D4
Change the sketch or your wiring to suit.
