I have been trying to sort this for a while. I am doing something stupid, I get that but I cannot see what. I can no longer read the DHT22: I am using a WeMos D1 Mini and trying to read a DHT22 for temp and humidity. It all initially worked fine then I replaced my laptop and I guessed I messed up the drivers for the WeMos.
// run on WeMos mini D1
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <ArduinoOTA.h>
#include <WidgetRTC.h>
#include "DHT.h"
#include <PID_v1.h>
#define CycleTime 30000 // sensor read and relay process frequency
//define pins
//Wemos board pin location:-
//3V3 D8 D7 D6 D5 D0 A0 DST
//5V G D4 D3 D2 D1 RX TX
#define SystemOnOffRelayPin D0
#define DehumidifierRelayPin D3
#define DHTTempHumiditySensorPin D4
#define Fan2RelayPin D5
#define Fan1RelayPin D6
#define Heater2RelayPin D7
#define Heater1RelayPin D8
#define DHTTYPE DHT11 // DHT 22 (AM2302)
//define Blynk virtual pins
#define vTempSetPoint V0
#define vHeaterActive V1
#define vFanActive V2
#define vDehumActive V3
#define vSystemOnOff V4
#define vEnvironmentalTemp V5
#define vEnvironmentalHumidity V6
#define vTerminal V7
#define vDehumidifierSetPoint V8
#define vSystemStatus V9
#define vVariableStatus V10
#define vSystemActive V11
//set up temphumidity sensor
DHT DHTTempHumititySensor(DHTTempHumiditySensorPin, DHTTYPE);
// set up timer function to repeat the sensor read/relay setting/blynk update activities
BlynkTimer DoProcessing; // DoProcessing is the procedure run every time the timer fires - precedure name is variable. see http://playground.arduino.cc/Code/SimpleTimer
// set up the blyn ternila widget to send debuging & status messages to.
WidgetTerminal BlynkConsole (vTerminal);
//WidgetRTC rtc;
// blynk key here
char BlynkAuth[] = "3bcf9c42589a46f6833c74a2a9bf37ee";
// define variables & set defaults
bool isFirstConnect = true; // Keep this flag not to re-sync on every reconnection
bool bSystemOn = false;
bool bHeaterActive = false;
bool bFanActive = false;
bool bDehumActive = false;
bool bDisplayStatus = false;
bool bDisplayVariable = false;
int iTempSetPoint = 25;
int iHeaterOnTemp = 23;
int iHeaterOffTemp = 27;
int iFanOnTemp = 27;
int iFanOffTemp = 20;
int iDehumidifierSetpoint = 50;
int iReadFailCount = 0;
float EnvironmentTemp;
float EnvironmentHumidity;
// one off initial setups
Blynk.begin(BlynkAuth,"","");
delay(10000);
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
wifiManager.setTimeout(180);
BlynkConsole.println("Firing Up"); // sends message to blynk terminal widget in blynk app on phone
BlynkConsole.flush();
Serial.println("connected...yeey :)");
// wifiManager.resetSettings(); // if want to delete ssid settings
// wifiManager.startConfigPortal("WeMos 01"); // make it load the portal
//fetches ssid and pass and tries to connect
//if it does not connect it starts an access point with the specified name
//and goes into a blocking loop awaiting configuration
if(!wifiManager.autoConnect("Monitor Status")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
ArduinoOTA.setHostname("Monitor Status"); //invoke to create the access point name & password
ArduinoOTA.setPassword("arduino");
ArduinoOTA.onStart([]() {
Serial.println("Start");
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
BlynkConsole.println("Ready");
DHTTempHumititySensor.begin();
DoProcessing.setInterval(CycleTime, ProcessControl);// set up timer
// rtc.begin();
// set up digital pins
pinMode(Heater1RelayPin, OUTPUT);// set mode
digitalWrite(Heater1RelayPin, LOW); // set to Off I think??
pinMode(Heater2RelayPin, OUTPUT);// set mode
digitalWrite(Heater2RelayPin, LOW); // set to Off I think??
pinMode(Fan1RelayPin, OUTPUT);// set mode
digitalWrite(Fan1RelayPin, LOW); // set to Off I think??
pinMode(Fan2RelayPin, OUTPUT);// set mode
digitalWrite(Fan2RelayPin, LOW); // set to Off I think??
pinMode(SystemOnOffRelayPin, OUTPUT);// set mode
digitalWrite(SystemOnOffRelayPin, LOW); // set to Off I think??
pinMode(DehumidifierRelayPin, OUTPUT);// set mode
digitalWrite(DehumidifierRelayPin, HIGH); // set to On I think??
// manage blynk virtual pins
BLYNK_CONNECTED() {
if (isFirstConnect) {
// Request Blynk server to re-send latest values for all pins when system fires up.
Blynk.syncAll();
isFirstConnect = false;
//main programme loop
ArduinoOTA.handle();
DoProcessing.run(); // Initiates SimpleTimer
//procedures & functions
void ProcessControl() { // processed by the timer set to frequency of CycleTime
//regardless of System On (V4) button
readSensor(); // read the sensors
// if the virtual System On (V4) button is high then do the processes
if(bSystemOn){
SensorFailure(); // if the sensor fails sets defaults
systemStatus(); // displays the system status & settings if virtual buttons active (V9 & V10)
controlHeatersAndFans(); // controls the heaters & fans based on set points (V0)
controlDehumidifier(); // controls the dehumidifier based on a set point (V8)
else{
systemOff(); // turns off all the relays and sets flags low
// sends all data to Blynk servers
sendDataToBlynk();
void readSensor(){
EnvironmentHumidity = DHTTempHumititySensor.readHumidity();
EnvironmentTemp = DHTTempHumititySensor.readTemperature();
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(EnvironmentTemp) || isnan(EnvironmentHumidity)) {
Serial.println("Failed to read from Environmental Sensor\n\r");
BlynkConsole.println("Failed to read from Environmental Sensor\n\r");
iReadFailCount ++;
else {
Serial.print("Humidity: ");
Serial.print(EnvironmentHumidity);
Serial.println(" %\t");
Serial.print(EnvironmentTemp);
Serial.println(" ËšC ");
BlynkConsole.print("Humidity: ");
BlynkConsole.print(EnvironmentHumidity);
BlynkConsole.println(" %\t");
BlynkConsole.print("Temperature: ");
BlynkConsole.print(EnvironmentTemp);
BlynkConsole.println(" ËšC ");
iReadFailCount = 0;
//if the sensor fails to read 10 times define defaults
void SensorFailure(){
if(iReadFailCount > 9){
//set relays
digitalWrite(Heater1RelayPin, LOW); // default to Off
digitalWrite(Heater2RelayPin, LOW); // default to Off
digitalWrite(Fan1RelayPin, LOW); // default to Off
digitalWrite(Fan2RelayPin, LOW); // default to Off
digitalWrite(SystemOnOffRelayPin, LOW); // default to Off
digitalWrite(DehumidifierRelayPin, HIGH); // default to On
//set flags
bSystemOn = false;
bFanActive = false;
bDehumActive = true;
//prints to console
BlynkConsole.println("System set to default");
Serial.println("System set to default");
//displays various system status if status variable is selected
void systemStatus(){
//BlynkConsole.print("vSystemStatus: ");
//BlynkConsole.println(vSystemStatus);
//BlynkConsole.print("vVariableStatus: ");
//BlynkConsole.println(vVariableStatus);
//display values is vSystemStatus (V9) selected
if (bDisplayStatus){
BlynkConsole.print("System: ");
BlynkConsole.println(bSystemOn);
BlynkConsole.print("Heater: ");
BlynkConsole.println(bHeaterActive);
BlynkConsole.print("Fans: ");
BlynkConsole.println(bFanActive);
BlynkConsole.print("Dehumidifier: ");
BlynkConsole.println(bDehumActive);
Serial.print("Heater status: ");
Serial.println(bHeaterActive);
Serial.print("Fan status: ");
Serial.println(bFanActive);
Serial.print("Dehum status: ");
Serial.println(bDehumActive);
//displays variable values is vVariableStatus (V10) selected before checking them
if (bDisplayVariable){
BlynkConsole.print("SetPoint:");
BlynkConsole.println(iTempSetPoint);
BlynkConsole.print("H_On:");
BlynkConsole.println(iHeaterOnTemp);
BlynkConsole.print("H_Off:");
BlynkConsole.println(iHeaterOffTemp);
BlynkConsole.print("F_On:");
BlynkConsole.println(iFanOnTemp);
BlynkConsole.print("F_Off:");
BlynkConsole.println(iFanOffTemp);
BlynkConsole.print("D_Off:");
BlynkConsole.println(iDehumidifierSetpoint);
Serial.print("TempSetPoint: ");
Serial.println(iTempSetPoint);
Serial.print("HeaterOnTemp: ");
Serial.println(iHeaterOnTemp);
Serial.print("HeaterOffTemp: ");
Serial.println(iHeaterOffTemp);
Serial.print("FanOnTemp: ");
Serial.println(iFanOnTemp);
Serial.print("FanOffTemp: ");
Serial.println(iFanOffTemp);
Serial.print("DehumidOff: ");
Serial.println(iDehumidifierSetpoint);
//turns on the heater & fan elements
void controlHeatersAndFans(){
// if env temp is <= iHeaterOffTemp variable & the heater flag is low switch Heater_Relay pin(s)"on"
if (EnvironmentTemp <= iHeaterOffTemp && !bHeaterActive){
digitalWrite(Heater1RelayPin, HIGH);
// digitalWrite(Heater2RelayPin, HIGH);
bHeaterActive = true; // toggle the heater flag
//if env temp is <= iTempSetPoint variable & the fan flag is high switch Heater2_Relay pin(s)"on"
//Bring on the second heater if struggling to get to temp
if (EnvironmentTemp <= iTempSetPoint){
//turn off the second heater once temp set point is reached
if (EnvironmentTemp >= iTempSetPoint && bHeaterActive ){
//if the env temp is >= to HeaterOff varibale & the heater flag is high then turn the Heater_Relay pin(s) off
if (EnvironmentTemp >= iHeaterOffTemp && bHeaterActive ){
bHeaterActive = false; // toggle the heater flag
// if env temp >= iFanOnTemp variable and fan is not running switch Fan_Relay pin(s) "on"
if (EnvironmentTemp >= iFanOnTemp && !bFanActive){
digitalWrite(Fan1RelayPin, HIGH);
digitalWrite(Fan2RelayPin, HIGH);
bFanActive = true;
// if env temp <= iFanOffTemp variable and fan is running then switch Fan_Relay pin(s) "Off"
if (EnvironmentTemp <= iFanOffTemp && bFanActive){
bFanActive = false;
// function to turn the dehumidifier relay pin "on"(D3)
void controlDehumidifier(){
// if the enviromental humidity value is < iDehumidifierSetpoint variable then turn the dehumidifier relay pin "off" else default to "on"
// iDehumidifierSetpoint is a Virtual slider V8, processed BLYNK_WRITE(vDehumidifierSetPoint)
if (EnvironmentHumidity <= iDehumidifierSetpoint) {
digitalWrite(DehumidifierRelayPin, LOW);
if (EnvironmentHumidity >= iDehumidifierSetpoint +1){
/* else{
void sendDataToBlynk(){
// V5 Environmental Temp
Blynk.virtualWrite(vEnvironmentalTemp, EnvironmentTemp);
// V6 Environmental Humidity
Blynk.virtualWrite(vEnvironmentalHumidity, EnvironmentHumidity);
// V1 Heater Active LED
if(bHeaterActive){
Blynk.virtualWrite(vHeaterActive,1023);
else {Blynk.virtualWrite(vHeaterActive,0);
// V2 Fan Active LED
if(bFanActive){
Blynk.virtualWrite(vFanActive,1023);
else {Blynk.virtualWrite(vFanActive,0);
// V3 Dehumidifier Active LED
if(bDehumActive){
Blynk.virtualWrite(vDehumActive,1023);
else {Blynk.virtualWrite(vDehumActive,0);
// V11 System Active LED
if(bSystemOn){
Blynk.virtualWrite(vSystemActive,1023);
else {Blynk.virtualWrite(vSystemActive,0);
//function to turn off the relays if the virtual System On (V4) button is low (off)
void systemOff(){
// turn all the relays off
// set flags
bFanActive = false;
// V0 Bylink slider widget to set the heater set point
BLYNK_WRITE(vTempSetPoint){
int iSetPoint = param.asInt();
//setting the enviromental variables
iTempSetPoint = iSetPoint;
iHeaterOnTemp = iSetPoint - 2;
iHeaterOffTemp = iSetPoint + 2;
iFanOffTemp = iSetPoint - 5;
iFanOnTemp = iSetPoint +1;
// V8 Bylink widget for the humidity level
BLYNK_WRITE(vDehumidifierSetPoint) {
//Humidity level to turn off the dehumidifier
int iHumidSetPoint = param.asInt();
iDehumidifierSetpoint = iHumidSetPoint;
// V4 system on/off button
BLYNK_WRITE(vSystemOnOff)
bSystemOn = param.asInt();
if (bSystemOn){
digitalWrite(SystemOnOffRelayPin, HIGH);
// V9 system status on/off button
BLYNK_WRITE(vSystemStatus)
bDisplayStatus = param.asInt();
/*//prints to console
BlynkConsole.print("bDisplayStatus =");
BlynkConsole.println(bDisplayStatus);
BlynkConsole.flush();*/
// V10 system status on/off button
BLYNK_WRITE(vVariableStatus)
bDisplayVariable = param.asInt();
/*BlynkConsole.print("bDisplayVariable =");
BlynkConsole.println(bDisplayVariable);
