i know what are you talking about. it is some kind of bug in the editor.
try to remove (delete) all the code, then copy / paste again from arduino ide.
it is important to insert an empty line before and after the code here in the editor. then select all the code and click the “<<>>” button. it should be ok then.
or try the method described here: [README] Welcome to Blynk Community!
