Hi friends. I have problem with DHT11 humidity reading. the humidity read successfully but after some times gone ! and labeled widget set to NAN
#define BLYNK_DEBUG
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include <BH1750.h> // https://github.com/claws/BH1750
#define I2C_SCL 12 // D6 Barometric Pressure Sensor (BMP085)
#define I2C_SDA 13 // D7
#include <DHT.h>
#define DHTPIN 4 //pin gpio 12 in sensor
#define DHTTYPE DHT11 // DHT 22 Change this if you have a DHT11
DHT dht(DHTPIN, DHTTYPE);
BH1750 lightMeter;
Adafruit_BMP085 bmp;
char auth[] = "a6ab62a2daf04bdab0d56fa85cd77955"; //Put your blink token
char ssid[] = "MikroTik Home"; //Put your SSID of your connection
char pass[] = "12345678"; //Put your Password of your connection
char server[] = "10.5.51.3";
float dst, bt, bp, ba;
char dstmp[20], btmp[20], bprs[20], balt[20];
bool bmp085_present = true;
WiFi.mode(WIFI_STA);
Blynk.begin(auth, ssid, pass, server, 8080); //insert here your SSID and password
Wire.begin(I2C_SDA, I2C_SCL);
if (!bmp.begin())
Serial.println("Could not find a valid BMP085 sensor, check wiring!");
//while (1) {}
timer.setInterval(1000L, sendWifi);
lightMeter.begin();
void sendWifi()
Blynk.virtualWrite(1, map(WiFi.RSSI(), -105, -40, 0, 100) );
void sendUptime()
float h = dht.readHumidity();
Blynk.virtualWrite(6, h); // virtual pin
uint16_t lux = lightMeter.readLightLevel();
Blynk.virtualWrite(4, lux);
float bp = bmp.readPressure()/1;
Blynk.virtualWrite(9, bp); // virtual pin
float ba = bmp.readAltitude();
Blynk.virtualWrite(7, ba); // virtual pin
float bt = bmp.readTemperature();
Blynk.virtualWrite(12, bt); // virtual pin
float dst = bmp.readSealevelPressure(529)/100;
Blynk.virtualWrite(13, dst); // virtual pin
Costas
March 14, 2018, 4:20pm
2
Ask Google about DHT and NAN.
you are super hero ( HULK )
the problem is solved by adding below code
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(5, t);
This is generally accepted solution which tries to handle erroneous results from DHT. But as one of recent discussion on this forum showed - it might be misleading IF the DHT constantly sends NaN
you will only see old, probably not actual data.
zodiac
March 14, 2018, 6:58pm
5
Of course it’s sending NAN with 1 second reading rate. Also, reading wifi signal strength every second makes no sense at all.
no its working without any delay or old data. the edited code below:
#define BLYNK_DEBUG
#include <SPI.h>;
#include <DHT.h>
#include <Wire.h>
BH1750 lightMeter;
if (!bmp.begin())
//while (1) {}
lightMeter.begin();
void sendWifi()
void sendUptime()
return;
Gunner
March 14, 2018, 8:46pm
7
You are trying to run two separate timers (and their functions) at the SAME time!!
The DHT11 timer is too fast anyhow (very slow sensor)… change it to something like 5015L. 5 second reads plus a 15ms offset to keep from bumping into the uptime timer.
