DHT11 + Ethernet W5100 + Controlling Ac Fan OFF/ON
hello engrs i am building a project Fan controlling Temperature so when Temperature reaches at level min 28 turned of the problem desnt turn off fan. please help me
i the code i had used is
#include <Ethernet.h>
#include <DHT.h>
char auth[] = “695ac0046cd746c7b75842922ebcccc6”;
#define W5100_CS 10
#define SDCARD_CS 4
int Pirpin =6;
int pins=12;
#define DHTPIN 7 // What digital pin we’re connected to
// Uncomment whatever type you’re using!
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
// This function sends Arduino’s up time every second to Virtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
void sendSensor()
float hum = dht.readHumidity();
float tem = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
t = ((int) (t * 10) / 10.0);
h = ((int) (h * 10) / 10.0);
if (isnan(hum) || isnan(tem)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
Blynk.virtualWrite(V6, tem);
Blynk.virtualWrite(V5, hum);
Blynk.syncVirtual(V6);
if (hum<=70 || tem<=28 )
{ digitalWrite(8,LOW);
digitalWrite(8,HIGH);
// Please don’t send more that 10 values per second.
// Blynk.digitalWrite(,HIGH)
//BLYNK_READD(V6)
//{ Blynk.virtualWrite(v6,val);
// BLYNK_WRITE(6){
// int TempDes = param.asInt();
// Blynk.virtualWrite(6,TempDes);
//BLYNK_WRITE(V0){
// Blynk.virtualWrite(V0,HIGH);
// Blynk.syncVirtual(V0);
void emailOnPirSensor()
// *** WARNING: You are limited to send ONLY ONE E-MAIL PER 15 SECONDS! ***
// Let’s send an e-mail when you press the button
// connected to digital pin 2 on your Arduino
int isPirSensor = !digitalRead(6); // Invert state, since button is “Active LOW”
if (isPirSensor) // You can write any condition to trigger e-mail sending
Serial.println(“Bath Room Lamp is On.”); // This can be seen in the Serial Monitor
Blynk.email("ukaash143@gmail.com", “Subject”, “You just Turned On Lamp Second ago…”);
// Or, if you want to use the email specified in the App (like for App Export):
//Blynk.email(“Subject: Button Logger”, “You just pushed the button…”);
pinMode(Pirpin, INPUT);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
pinMode(pins, OUTPUT);
pinMode(8,OUTPUT);
Blynk.begin(auth);
dht.begin();
Blynk.email("ukaash143@gmail.com", “Subject”, “My Blynk project is online.”);
//Blynk.begin(auth, “blynk-cloud.com”, 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8442);
// For more options, see Boards_Ethernet/Arduino_Ethernet_Manual example
getPirValue();
// int PirValue=digitalRead(Pirpin);
// if(PirValue==HIGH)
// Blynk.notify(“Bath Room Lamp Is ON”);
// //BATHROOM.on();
// Blynk.virtualWrite(V4,HIGH);
// delay(1000);
// else
// //Blynk.notify(“Bath Room Lamp Is OFF”);
// // BATHROOM.off();
// // Blynk.digitalWrite(D12,LOW);
// delay(1000);
void getPirValue(void)
int Pirpin =6;
int pirValue = digitalRead(Pirpin);
if (pirValue)
Serial.println("==> Motion detected");
Blynk.notify(“T==> Motion detected”);
digitalWrite(12, pirValue);
Please help us and yourself by following the directions as shown in the info you deleted to post this, as shown in the welcome topic, and as repeated, repeadly, often, much, throughout this forum…
FORMAT YOUR CODE :stuck_out_tongue:
Blynk - FTFC
