DHT 11 library and NodeMCU problem
Hello, after a few plays with the Blynk witgets I started to make a motorhome controll system.
I like to place the NodeMCU v1.0 with a DHT 11 to measure the temperature and huminity. I add the DHT library to the Arduino 1.6.6 IDE but as soon the compiler sees the syntax:#include"DHT.h". I get a compiling error.
When I compile the syntax as if a UNO board is installed the error disapear. So it looks like the compilers has problems to compile it for the NodeMCU.
Is there a way to solve this?
Greetings André
Problem not solved but changed dht11 to sht1x and changed dht.h to sht1x.h and program runs ok!
thanks all guys!
