Device wasn't online
I am using an arduino uno with an HC-05 Bluetooth module to control 2 DC motors. The motor driver I’m using is the Adafruit tb6612. When I try to connect with a Samsung Galaxy (I’ve tried on multiple versions), it says I’ve paired to the HC-05 but the Blynk app still says “Device wasn’t online yet.” I’m relatively new to programming, but if I’m understanding all the examples and forums on here correctly, this code should get input from two different joysticks to control two different motors independently. Is there anything I need to include in my code to make sure the app can connect to the device? Or am I dealing with a hardware issue?
#define A_IN1 8
#define A_IN2 9
#define B_IN1 12
#define B_IN2 13
#define PWMA 5
#define PWMB 6
char auth[] = "40JmYy0s4MgMhf45nQ0y4_s_07OKzi1G";
SoftwareSerial SerialBLE(10, 11); // RX, TX
  SerialBLE.begin(9600);
  Blynk.begin(SerialBLE, auth);
  pinMode(A_IN1, OUTPUT);
  pinMode(A_IN2, OUTPUT);
  pinMode(B_IN1, OUTPUT);
  pinMode(B_IN2, OUTPUT);
  // pinMode(Standby, OUTPUT);
// left motor
BLYNK_WRITE(V1) {
  // setup variables for joystick
  int x = param[0].asInt();
  int y = param[1].asInt();
  // move forward if joystick pushed up
  if (y > 128) {
    digitalWrite(A_IN1, HIGH);
    digitalWrite(A_IN2, LOW);
    analogWrite(PWMA, y);
  // move backward if joystick pushed down
  else if (y < 128) {
    digitalWrite(A_IN1, LOW);
    digitalWrite(A_IN2, HIGH);
  // stop if no joystick input
// right motor
BLYNK_WRITE(V2) {
  if (y > 128) {
    digitalWrite(B_IN1, HIGH);
    digitalWrite(B_IN2, LOW);
    analogWrite(PWMB, y);
  else if (y < 128) {
    digitalWrite(B_IN1, LOW);
    digitalWrite(B_IN2, HIGH);
Not all functionality works fully/correctly with Bluetooth.
The Online notifications might be one of those things.
