Device was disconnected
Hello
Can you please look at my code is there a mistake I find since no error because the Blynk app always indicates “Device was disconnected”
#include <OneWire.h>
#define ONE_WIRE_BUS 13
char auth[] = "403bc91d69861eb5c4bcf";
char ssid[] = "v.....";
char pass[] = "098500853402613";
int Sensorvalue=0;
int tempout=0;
int sensorPin=A0;
int sensorValuePercent=0;
WidgetLCD lcd(V7);
void sendTemps()
  float tempout = sensors.getTempCByIndex(0);
  Serial.println(tempout);
  Blynk.virtualWrite(V4, tempout);
    int Temperatur = tempout;
   if (Temperatur < 9.99)
  Blynk.setProperty(V4, "color", "#2ECCFA");
  Blynk.setProperty(V4, "label", "arsch kalt");
else if (Temperatur > 10 && Temperatur < 19.99)
  Blynk.setProperty(V4, "color", "#00FF00");
  Blynk.setProperty(V4, "label", "Temperatur normal");
else if (Temperatur > 20 && Temperatur < 69.99)
 Blynk.setProperty(V4, "color", "#FE2E2E");
  Blynk.setProperty(V4, "label", "schön warm");
timer.setInterval(3001, sendTemps1);
timer.setInterval(3001, sendTemps);
  sensors.begin();
void sendTemps1()
  Sensorvalue = analogRead(A0);
  Sensorvalue = map(Sensorvalue, 0, 1023, 1023, 0);
  sensorValuePercent = (Sensorvalue / 1023) * 100;
  Blynk.virtualWrite(V5, Sensorvalue);
  delay(3001);
  int feucht = Sensorvalue;
   if (feucht < 50.99)
 lcd.print(5,1,"trocken  ");
  Blynk.setProperty(V5, "color", "#E10C28");
  Blynk.setProperty(V5, "label", "Blumenerde trocken");
  lcd.print(2, 0,"Feuchtigkeit");
  Blynk.setProperty(V7, "color", "#F957FC");
else if (feucht > 51 && feucht < 125.99)
 lcd.print(5,1,"feucht  ");
  Blynk.setProperty(V5, "color", "#04B404");
  Blynk.setProperty(V5, "label", "Blumenerde feucht");
else if (feucht > 126 && feucht < 200.99)
 lcd.print(5,1," nass  ");
 Blynk.setProperty(V5, "color", "#00CCFF");
  Blynk.setProperty(V5, "label", "Blumenerde nass");
You need to avoid delays. This is not very effective way to go,
Ah ok delay(3001); get out
Blynk.setProperty(V4, “label”, “arsch kalt”); made me a smile on my face :slight_smile:
I Would prefer such solution:
int Sensorvalue=0;
int tempout=0;
int sensorPin=A0;
WidgetLCD lcd(V7);
#define UPDATE_AFTER_SECONDS 4
unsigned long SecTimerValue;
unsigned long UpdateTimer;
void UpdateSectimer() {
	SecTimer++;
void sendTemps()
  timer.setInterval(3001, UpdateSectimer);
  sensors.begin();
void sendTemps1()
  delay(3001);
   if (feucht < 50.99)
  if (UpdateSectimer < SecTimerValue) {
	  if (Blynk.connected()) {
		sendTemps();
		sendTemps1();
	  UpdateSectimer = SecTimerValue + UPDATE_AFTER_SECONDS;
af_bln / The code does not work Below is always ‘SecTimer’ was not declared in the scope :confused:
Edit this function:
SecTimerValue++;
Hello Arduino Still shows errors at see below something with C ++ error
 if (UpdateSectimer < SecTimerValue) { <<< ISO C++forbidscomparsion between pointer and integer (-fpermissive)
    sendTemps();
    sendTemps1();
UpdateSectimer should be UpdateTimer I think. You are now comparing a void function (UpdateSectimer) with a long type variable.
Ups, yes you are right.
