I am attempting to connect my Particle Photon to Blynk for the first time and am running into issues. I followed the steps to use the Quickstart Device but it seems to get stuck in the Blynk.begin() function. I tried to specify ssid and password by doing Blynk.begin(auth,ssid,pass) as I have seen others do but the particle version of the Blynk library doesn’t allow this. I also tried using Blynk.config(auth) and Blynk.connect() but it times out in the connect function. I’m not sure where to proceed from here. The code flashes onto my particle photon just fine. Has anyone else connected a Particle Photon to Blynk? Any advice on how to debug this issue?
Here is the code below. It is the same as the example code given by Blynk.
#include <blynk.h>
#define BLYNK_TEMPLATE_ID "TMPLRoT80BUE"
#define BLYNK_DEVICE_NAME "Quickstart Template"
#define BLYNK_AUTH_TOKEN "" //(deleted for privacy)
//deleted for privacy
char ssid[] = "";
char pass[] = "";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
delay(5000); // Allow board to settle
Blynk.begin(auth);
//Blynk.config(auth);
//bool connect = Blynk.connect();
//Serial.println(connect);
// to avoid delay() function!
