I use iOS version /2.18.0 (1)/ and use Device Tiles. And I created 2 teplates and all is OK. But I create third template all OK only until restat application - all components from third template are lost…
JJ
JJ
are you using blynk in the cloud or on a local server?
I am use blynk in the cloud.
ok, I had a similar issue but with (outdated) local server. This is not the case with you so I would wait for a dev to respond.
