added device selector widget -> it shows all 3 devices in the list
several days later i added a new device to the project, but the new device didn’t shows up in device selector list
bug 2:
i’ve tried to delete and re add device selector:
if i try to delete from device selector widget settings, it warns me that the widget is hooked up to several other widgets, and first i have to delete those. i didn’t want to delete the other widgets, so i tried to delete device selector with drag’n’drop to the upper right corner of the screen. this way i didn’t complained about the hooked up widgets.
so, now i’ve re added the new device selector, and AFTER restarting the app, the 4th device showed up in the list.
bug 3:
the super chart widget which was hooked up to the deleted device selector it is broken now, i can’t select any virtual pins or device. see the photos:
It’s not a bug. When you had added a new device - you need to go to device selector settings and attach the new device to it. I guess it would be incorrect to add every new device to an existing device selector.
Yep, we’ll add confirm alert on such removal for widget’s that needs this confirm. The third issue is a result of the second one. That warning was not about removing other widgets, but about moving them to other device/selector/tag (maybe we should make it more accurate). I’ve rechecked warning and it is confusing: we’ll fix it too.
PS please mark me or Dmitriy if you are creating a bug report thread
