Device not showing online
I have connected arduino uno with ESP8266- 01. I am trying the blink example https://examples.blynk.cc/?board=Arduino%20Uno&shield=ESP8266%20WiFi%20Shield&example=GettingStarted%2FBlynkBlink
On the serial monitor I get the message as wifi connected but it doesn’t shows on the app.
The message i get on serial monitor is
[598] Connecting to Ranjan
[3782] AT version:1.3.0.0(Jul 14 2016 18:54:01)
SDK version:2.0.0(656edbf)
compile time:Jul 19 2016 18:44:44
OK
[13049] +CIFSR:STAIP,“192.168.0.4”
+CIFSR:STAMAC,“a0:20:a6:05:68:c7”
[13057] Connected to WiFi
Here is my code:
#include <ESP8266_Lib.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "Ranjan";
char pass[] = "my wifi password";
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
  Blynk.begin(auth, wifi, ssid, pass, "35,154,12,218");
I have set the baud rate of esp to 9600 by using command (AT+UART_DEF=9600,8,1,0,0), used external power source.
Connections are done as:-
VCC - 3.3V
CH_PD - 3.3V
TX - Pin 2
RX - Pin 3
GND - GND
When processing the IP this way, I believe those need to be periods, not commas. At least that’s how I do.
Use the Debug command and see what is happening in more detail.
Hey @Gunner, thanks for your reply. :smile:
I corrected those mistakes but still the problem persists. :disappointed_relieved:
Tried that, serial monitor just shows following
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.5.4 on Arduino Uno
[3783] AT version:1.3.0.0(Jul 14 2016 18:54:01)
OK
[9052] +CIFSR:STAIP,“192.168.0.5”
[9058] Connected to WiFi
The IP address of the Blynk server that you’re trying to connect to seems odd.
It’s clearly not a local server on the same network as your ESP, as that’s being allocated an IP address in the 192.168.0.xxx range.
If I ping 35.154.12.218 then I get:
Pinging 35.154.12.218 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 35.154.12.218:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
If you’re using the Blynk cloud servers then why not use:
Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
Hey @PeteKnight, thanks for replying.
I am not using Blynk Cloud server. I have my own server on AWS EC2 that’s why ping shows request timed out as ping requests are blocked by amazon.
In that case, I think you probably need to specify the appropriate port in the Blynk.begin command.
Yes… I didn’t check the IP as I also thought it was intended for the Cloud Server. With Local Server you need port 8080, unless you purposely changed something with port forwarding.
With Blynk’s cloud server it is working fine. But when I use my server and use Blynk.begin(auth, wifi, ssid, pass, IPAddress(35,154,12,218), 8080); i get error in compiling the code as ‘IPAddress’ was declared in this scope. :tired_face:
You do it this way…
Blynk.begin(auth, wifi, ssid, pass, "35.154.12.218", 8080);
Although I like this way…
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxx";
char server[] = "xxx.xxx.xxx.xxx";  // IP for your Local Server
int port = 8080;
WiFi.begin(ssid, pass);
Blynk.config(auth, server, port);
Blynk.connect();
@Gunner @PeteKnight
Thank You very much for helping me. It is working now. :smile:
I think the Blynk Example Browser should be updated as it shows that code which is giving error.
I never used that way, but I suspect there was a reason.
And you can always report an error, there is a button for that in the Example Maker
