/** Voice controlled house lights with Google Assitant
* Instructable contest
* Mridul Mahajan
#define EspSerial Serial1
#include<SPI.h>
#include <ESP8266_Lib.h>
char auth[] = "guwbokZWg1UNAuyUcXYtk_GI3s2ck2R2";
char ssid[] = "MMVS";
char pass[] = "123";
SoftwareSerial EspSerial(2, 3); // RX, TX of ESP8266
String s; //to store incoming text ingredient
BLYNK_WRITE(V0) // it will run every time a string is sent by Blynk app
s=param.asStr();
Serial.print(s); //string sent by Blynk app will be printed on Serial Monitor
if(s=="on")
digitalWrite(7, LOW); //Pin 7 has been set in setup()
else if(s=="off")
digitalWrite(7, HIGH);
else{
Serial.print("Say on or off");
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
pinMode(7,OUTPUT); //Pin 7 is set to output
// Set ESP8266 baud rate
The aim of my project is to be able to make a switch which can be controlled by google assistant…:
I’ve used
- 5V relay
- esp8226
- arduino UNO
I’ve created an IFTTT Applet and blynk project in the app.
This line of code shouldn’t be in your sketch, as the Uno doesn’t have a Serial1 port.
What type of ESP8266 board are you using, and how have you wired that and the Uno together?
Thanks for replying Pete!!!
ESP8266 wifi board is what I’ve used
Connections between Arduino,ESP8266 and relay module:
Arduino <-----------------------------------------------> ESP/Relay
Pin 7 ------------------------------------------------------- IN of relay
Pin 2 -------------------------------------------------- RX pin of ESP
Pin 3 -------------------------------------------------- TX pin of ESP
RESET-------------------------------------------- RESET pin of ESP
GND 1 -------------------------------------------- Ground pin of ESP
GND 2 -------------------------------------------- Ground pin of relay
+3.3V ------------------------------------------------------ Vcc of ESP
+5V ------------------------------------------------------ Vcc of relay
With serial communications you always connect Rx —> Tx and vice versa, so pin 2 of your Uno (SoftwareSerial Rx) needs to go to Tx on your ESP-01
Your connection of the two Reset pins is a new one on me and makes no sense to me, but you seems to be missing a connection between CH-PD on the ESP-01 and 3v3
I was initially guided by :
https://www.instructables.com/id/Control-House-Lights-With-Google-Assistant-Using-A/ … so could you please help me with this one…
And 3v3 pin of the esp is connected to 5V port of the UNO
I think you should discuss that with the author of the instructable.
Well thanks for the advice Pete!
But since he isn’t responding can we find out our own version of the solution for this problem…
I’ve given you my thoughts on what’s wrong, but your response was “but the guide I’m following says to do this instead…”
Oh! Okay Gotcha Thanks!
Have a Nice day!
