https://pastebin.com/SYRcwF41
char auth[] = "";
char ssid[] = "";
char pass[] = "";
#define BLYNK_DEBUG
#define BLYNK_NO_BUILTIN // Disable built-in analog & digital pin operations
#define BLYNK_NO_FLOAT // Disable float operations
#include <IRremoteESP8266.h>
#include <IRsend.h>
#include <BlynkSimpleEsp8266_SSL.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
extern "C" {
#include "user_interface.h"
IRsend irsend(D3);
int khz = 38;
uint16_t ACOnColdCode[] = {8936,4440,704,1576,716,480,656,536,660,1624,656,1624,656,1628,652,540,660,536,656,1624,660,1624,656,540,652,540,660,536,656,536,656,540,652,540,652,544,660,536,656,536,656,540,652,1628,652,1632,660,1620,660,536,656,536,656,540,652,544,660,532,656,1628,652,540,652,1632,652,540,660,536,656,1624,656,540,652,19836,656,536,656,540,652,540,652,544,660,532,688,508,684,508,684,512,680,516,688,504,688,508,684,508,684,512,680,1600,660,536,688,504,688,512,680,512,680,512,688,508,684,508,684,512,680,520,684,504,688,504,688,508,684,512,680,512,692,504,688,504,688,508,684,1596,684};
uint16_t ACOffCode[] = {8964,4412,660,1624,656,536,656,540,656,540,648,1632,660,1624,660,532,660,536,688,1592,688,1596,652,540,684,512,680,516,688,504,688,508,684,508,684,512,680,512,684,512,688,508,688,504,688,1596,684,1596,684,512,680,512,692,504,688,504,688,508,684,1596,688,508,684,1600,680,512,680,516,688,1592,688,508,684,19800,688,508,684,512,680,512,680,516,688,504,688,508,684,508,684,512,680,512,680,516,676,516,688,508,684,512,680,1600,684,512,680,512,688,508,684,508,688,508,684,508,684,512,680,516,688,504,688,508,684,508,684,512,680,516,688,504,688,508,684,508,684,512,680,512,680};
uint16_t ACOnHotCode[] = {};
uint16_t FanToggleCode[] = {1324,356,1304,376,440,1248,1272,408,1272,416,432,1260,440,1256,444,1252,492,1208,440,1256,440,1252,1280,6968,1272,404,1304,376,476,1212,1304,376,1304,384,468,1228,440,1256,444,1252,436,1260,440,1256,444,1252,1308,6920,1308,372,1300,380,468,1220,1300,380,1300,388,472,1220,468,1228,472,1224,476,1224,464,1232,468,1228,1300,6944,1308,368,1300,380,472,1216,1300,380,1300,388,472,1224,464,1232,468,1228,472,1224,468,1228,472,1224,1304,6952,1300,376,1300,380,472,1216,1300,380,1300,388,464,1228,472,1224,476,1220,468,1232,468,1228,472,1220,1308};
uint16_t BiasLightOn[] = {9150,4400, 600,550, 600,500, 600,550, 600,550, 600,500, 600,550, 600,500, 650,500, 600,1650, 550,1650, 600,1600, 600,1650, 600,550, 600,1600, 650,1550, 650,1600, 650,1550, 650,1600, 600,500, 650,500, 650,500, 600,500, 650,500, 600,500, 650,500, 650,500, 600,1600, 650,1550, 650,1600, 600,1600, 650,1600, 600,1600, 650};
uint16_t BiasLightOff[] = {9150,4400, 600,500, 600,550, 600,550, 600,500, 600,550, 600,500, 600,550, 600,550, 600,1600, 600,1650, 600,1600, 600,1600, 650,500, 650,1600, 600,1600, 650,1550, 650,500, 650,1550, 650,500, 650,500, 600,500, 650,500, 600,500, 650,500, 650,1600, 600,500, 650,1600, 600,1600, 650,1600, 600,1600, 650,1550, 650,1600, 650};
bool preventBiasLightToday = false;
void SendIRCommand(uint16_t* IRCommandArray, uint16_t len){
irsend.sendRaw(IRCommandArray, len / sizeof(IRCommandArray[0]), khz);
// indicate on control led that a transmission is ongoing
turnControlLedOn1Sec();
/// region bias light
void CheckTurnBiasLightOn(){
timeClient.update();
int currHour = (timeClient.getHours() + 2) % 24;
if(currHour > 6 && currHour < 22 && !preventBiasLightToday){
SendIRCommand(BiasLightOn, sizeof(BiasLightOn));
void preventBiasRelight(){
void toggleBiasLight() {
Serial.print("BiasLight");
if(preventBiasLightToday){
Serial.println(" on");
else{
Serial.println(" off");
timer.setTimeout(21600000, preventBiasRelight);
SendIRCommand(BiasLightOff, sizeof(BiasLightOff));
preventBiasLightToday = !preventBiasLightToday;
// BiasLight
BLYNK_WRITE(V7)
int pinValue = param.asInt();
if(pinValue == 1){
toggleBiasLight();
/// endregion bias light
// ACOnCold
BLYNK_WRITE(V1)
if(pinValue == 1){
//ACOnCold();
timer.setTimer(500, ACOnCold, 3);
// enter area
BLYNK_WRITE(V5)
Serial.println("enter area");
if(pinValue == 1){
void ACOnCold(){ // todo to be refactored
Serial.println("ACOnCold");
SendIRCommand(ACOnColdCode, sizeof(ACOnColdCode));
// ACOff
BLYNK_WRITE(V2)
if(pinValue == 1){
SendIRCommand(ACOffCode, sizeof(ACOffCode));
Serial.println("ACOff");
// exit area
BLYNK_WRITE(V8)
Serial.println("exit area");
if(pinValue == 1){
// ACOnHot
BLYNK_WRITE(V3)
if(pinValue == 1){
SendIRCommand(ACOnHotCode, sizeof(ACOnHotCode));
Serial.println("ACOnHot");
// fanToggle
BLYNK_WRITE(V4)
if(pinValue == 1){
SendIRCommand(FanToggleCode, sizeof(FanToggleCode));
Serial.println("fanToggle");
// control led
BLYNK_WRITE(V0)
if(pinValue == 1){
// turnControlLedOn1Sec();
toggleControlLed();
bool controlLedToggle = false;
void toggleControlLed(){
if(controlLedToggle){
timer.setTimeout(1000L, turnControlLedOff);
else{
turnControlLedOff();
controlLedToggle != controlLedToggle;
void turnControlLedOn1Sec(){
Serial.println("turnControlLedOn1Sec");
digitalWrite(LED_BUILTIN, LOW);
timer.setTimeout(1000, turnControlLedOff);
void turnControlLedOff(){
Serial.println("turnControlLedOff");
digitalWrite(LED_BUILTIN, HIGH);
Serial.println(ESP.getResetInfo());
// Serial.println(ESP.getResetInfoPtr());
pinMode(D3, OUTPUT);
digitalWrite(D3, LOW);
pinMode(BUILTIN_LED, OUTPUT); // set onboard LED as output
digitalWrite(BUILTIN_LED, HIGH); // led logic is inverted
Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY);
irsend.begin();
// Force the ESP into client-only mode
WiFi.mode(WIFI_STA);
// Enable light sleep
// wifi_set_sleep_type(LIGHT_SLEEP_T);
timeClient.begin(); // to turn on the bias light in the morning automatically
CheckTurnBiasLightOn();
timer.setTimer(1800000, CheckTurnBiasLightOn, 1);
Blynk.syncAll();
I added the blynk debug and Serial.println(ESP.getResetInfo()); just now.
I didn’t check in the router to see if it’s still connected but I see in the Blynk app that it was disconnected.
