"device is offline" when Blynk connect to HM-10
All is well.
With Mega 2560, HM-10
However, I had successfully accessed made my project work 2 month ago, yet it can’t work and show up “device is offline” on the app.And the auth token is right.
Appreciate for anyone’s help.
#define BLYNK_DEBUG
//IN1 左前 7
//IN2 左後 6
//IN3 右前 4
//IN4 右後 5
//ENA 9 左
//ENB 8 右
char auth[] = "ba9497ebbb0a48aeb90d4db5da7bbbea";
SoftwareSerial SerialBLE(10,11); // RX, TX
int speedA=9,IN1=7,IN2=6,IN3=5,IN4=4,speedB=8;
int speeds=60;
char val;  // 儲存接收資料的變數
String CarCommand = "FBLRS0123456789q" ;
  Serial.begin(38400);
pinMode(speedA,OUTPUT);
  pinMode(speedB,OUTPUT);
  pinMode(IN1,OUTPUT);
  pinMode(IN2,OUTPUT);
  pinMode(IN3,OUTPUT);
  pinMode(IN4,OUTPUT);
  SerialBLE.begin(38400);
  Blynk.begin(SerialBLE, auth);
BLYNK_WRITE(V1) {
  // You can also use:
  // String i = param.asStr();
  // double d = param.asDouble();
  Serial.print("V1 Slider value is: ");
  Serial.println(pinValue);
  digitalWrite(4,HIGH);
  digitalWrite(5,LOW);
  digitalWrite(6,LOW);
  digitalWrite(7,HIGH);
  analogWrite(9,60);
  analogWrite(8,60);
BLYNK_WRITE(V2) {
  digitalWrite(7,LOW);
  analogWrite(9,60);
  analogWrite(8,60);
BLYNK_WRITE(V3) {
  digitalWrite(4,LOW);
  analogWrite(9,60);
  analogWrite(8,60);
BLYNK_WRITE(V4) {
  digitalWrite(5,HIGH);
  digitalWrite(6,HIGH);
  analogWrite(9,60);
  analogWrite(8,60);
BLYNK_WRITE(V5) {
  digitalWrite(9,0);
  digitalWrite(8,0);
BTW my serial monitor only shows connecting and login timeout like the photo below, but I have already connected to the HM-10.
The Mega has 3 extra Hardware Serial ports, and SoftwareSerial will be stressed at anything above 9600, so you should switch to one of those HW ports for more reliability.
E.g. Serial1: 19 (RX) and 18 (TX)
//SoftwareSerial SerialBLE(10,11); // RX, TX
Serial1.begin(38400);
Blynk.begin(Serial1, auth);
Thanks for your reply.
However, after varying the pins and code, problem didn’t solve,and my Blynk app can’t connect to the HM-10 as well.
On the other hand, I have also tried to change the baud from 38400 to 9600, it didn’t work, either
